Need help on vacation
Old Aug 25, 2008 | 09:19 AM
skatsuf's Avatar
skatsuf
Default Need help on vacation
My Service ABS light and Service Traction Control warning light has come on the dash. I have been driving in alot of rain. Could this cause this to give a false reading. If not, is it safe to still drive the car?
Thanks in advance for any help.
Old Aug 25, 2008 | 10:20 AM
Dave68's Avatar
Dave68
Yes, if you drive carefully, there shouldn't be any problems. List your codes from the D.I.C. and you'll get some suggestions as to what to do, next.
Old Aug 25, 2008 | 10:25 AM
slothy's Avatar
slothy
ya it safe to drive, just make sure you're not wearing your heavy shoes :P - you can send it to absfixer.com and have him fix it, quick turnaround!
Old Aug 25, 2008 | 10:30 AM
mitchcole's Avatar
mitchcole
check the brake fluid level. It's cheap first pass
Old Aug 25, 2008 | 12:27 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The largest problem seen with heavy rain is possible plugged up udders therefore water draining into the passenger side and onto the BCM. Pulling the codes as already suggested is the the smartest thing to do as it will point you in the right direction.
To Need help on vacation
