code help
Old Sep 19, 2008 | 10:47 AM
22655td's Avatar
22655td
Default code help
I have two codes I can't figure out.
One is from the PCM. PO704 C HC It is a clutch switch circut. I haven't a clue, it works fine
The other one is from the HVAC system it is BO333C. I can't find it in my cheat sheet. I do know I have a bad ambeint sensor as it shows 69 degress all the time. The AC works fine but when I try to reset the code the AC blows hot for a few seconds while the code is trying to reset then the AC blows cold again, ANY CLUES WOULD BE GREAT
