Need help....
Old Sep 23, 2008 | 08:50 AM
z0sleeper's Avatar
z0sleeper
Default Need help....
Hey guys,
I had speedinc install a DTE stage 2 diff on my 01 z car made 416 rwhp ran the car at the track few times with nittos just couldnt hook. I got myself M/T drags 315 's and first try off the line at 3500 launch something broke car would move only for few feet before getting stuck.
Towed the car back to speedinc and diff was sent to DTE to see what they can do about the broken 390 gear. Cost me $600 bucks to replace the gear and some bearing. Anybody else here have this problem with DTE if i would of known before that the diff was that weak i would of kept the stock one on and not paid 1200 for DTE stage 2. Larry told me to go with there stage 4 now since there putting a AA corvette kit on it. (Larry great guy over there at speedinc).
Old Sep 23, 2008 | 09:29 AM
lucky131969's Avatar
lucky131969
Originally Posted by z0sleeper
Hey guys,
Did you at least call DTE and talk to them before questioning their product on the forum? If I'm not mistaken, the stage 2 only has a hardend left output shaft, and a stock right. So the gear itself actually broke, or the output shaft?
I know plenty of guys running DTE differentials, making 200+ RWHP more than you, and they have dozens of passes at the strip, but then again, they also opted for a stage package made for drag racing, and are typically running a brace or 3 rib case.
Old Sep 23, 2008 | 09:45 AM
z0sleeper's Avatar
z0sleeper
I did not call DTE only cause Larry told me he would see what they can do about it and since it was speedinc calling i was hoping they could do better then me on that part. Only things that broke from what i was told was gear and some bearings got some shavings in it. I'm just thinking i paid 1,200 bucks for a gear and hardend left side with a core? hmmm lol
Old Sep 23, 2008 | 09:54 AM
lucky131969
Did the differential come from DTE, or did Speed Inc already have it? Reason I ask: according to DTE's website, a stage 2 differential is $1649, where a stage 1 is $1299. Both are exchange or with your core. So Speed Inc was able to get you a stage 2 for almost $450 off ?
Old Sep 23, 2008 | 01:55 PM
DTE Powertrain's Avatar
DTE Powertrain
Collections Hold
Hey guys,
The information you have posted is entirely incorrect, inaccurate and completely false! I suggest that if you have a questions about something, you should call us directly, instead of posting such inaccurate and entirely false data on a public board...
The differential model you placed the order for through your DTE Product Dealer and the differential that we received the order for was for a ***STAGE 1*** street differential, NOT a Stage 2 or anything of the like. Why you chose a street differential to go drag racing with (especially with a 6-speed transmission) is beyond our understanding, so if that was your intent from the beginning, than a Stage 1 model was not for you in the first place- as it's not built for drag racing use like our other heavier duty models are...
Often times folks go for the cheapest differential they can possibly get their hands on irregardless of the intended application, which is a foolish decision; because they often buy a unit that is under-rated for their application since they based their decison on price alone and then they are confused on why it failed. We get this all the time....
Furthermore, the only thing that was wrong with the unit was a gear failure and everything else in the unit was like new, so the only parts that required replacement was the ring & pinion itself, NOT the bearings also.....
Lastly, we knew that you had put this unit on the track after we found out you broke it, even though it was the wrong unit you chose for the application and typically, racing parts aren't covered under warranty. ***HOWEVER***, we informed your dealer that we would ***STILL*** cover you to some extent and eat all the labor operations/charges to get you going again if you covered the parts- basically a 50/50 split, even though we didn't have to do anything based on the differential documentation we provided you. We wanted to assist in the situation if we could. Plus, I've squeezed this unit in our already tight schedule by coming in early and staying late yesterday to get this done for you faster than the norm.
Now you still come on this board and bash us anyway for the help we gave you?????? WOW! Maybe a simple phone call first if you had a question, instead of the "attack first and ask questions later" internet behavior??
We're here to help and always have been, but as anyone who knows me personaly, already knows that I'll go the extra mile to help anyone in any way I can if they conduct themselves with us the way they also like to be treated. However, the door will immediately slam shut if we're needlessly attacked online for no good reason...
As always, I appreciate your business, as I do others and I encourage you to **CALL** here first if you have a question about something, rather than what we've seen here today- as that will get you much farther, much quicker. Larry is indeed a good guy over there and he builds a LOT of very high HP cars using our HD racing differentials with outstanding success, so next time, if you have a question- again, please call one of us first and we'll do what we can to help you.
Your differential ships out today back to Larry.
Regards,
Phil
Old Sep 23, 2008 | 04:24 PM
z0sleeper's Avatar
z0sleeper
Regards,
Phil
All i asked was if anybody else had a problem with the stage 2 or 1 whatever it is that speedinc sold me.... I am not putting DTE down at all only thing im saying is if anybody else had my problem and if they had to pay the same price i paid... I'm not talking smack about your rearends and parts you use. I do plan on buying a stage 4 soon.... (Please delete post ) Thanks P.s thanks for clearing that up and if i really did have a problem and was pissed i would of called...
Old Sep 23, 2008 | 05:31 PM
DTE Powertrain
Collections Hold
No worries and Larry should have your differential back in the next day or so.
Phil
Old Sep 24, 2008 | 07:15 PM
lucky131969
Now come on bro, you mean you didn't even know what you were buying? Did you explain to Speed Inc how you intended on using the car? I find it hard to believe they would have recommended a Stage 1 diff if they knew up front you intended on drag racing, not to mention 3500 rpm launches with M/T's.
Old Sep 24, 2008 | 08:06 PM
Bluefire's Avatar
Bluefire
(crickets chirping)...
Old Sep 24, 2008 | 08:47 PM
z0sleeper's Avatar
z0sleeper
Let's not make this 50 pages long ... I'm done talking about it thanks for the help.
To Need help....
