Transmission Issues MN6
Put on some MT ET Street Radials today and didn't do any hard lauches or power shifting but after a little while messing around I tried doing a high RMP shift from 1 to 2 and it wouldn't let me go into gear then the same thing happened again from 2 to 3.
Any ideas ? ? ? Syncros
Should I get on the phone with Rodney @ RPM?
Thanks for the help,
John
Levittown, NY
I have the same problem on a hard run, it can happen in any gear. It doesn't happen with wheelspin, so I'm sure it's a product of making big power and stickin it with good tires.
One day at the track I had a nice launch with a 1.50 60' and it locked me out of shifting into 2nd! Other times it's locked out of 3rd and 4th. See the 10.6 in car video in my sig, this is the only way I can get down the track, by completely lifting the throttle on each shift.
It seems to be a disengagement problem under load. I also have a Tex clutch and maybe that's the nature of it. I recently installed a throwout shim with an adjustable master. I have not been back to the track to test yet, and on the street I spin too much to repeat the problem. Sad part is one of our tracks closes this weekend and today got rained out. The other track has one more TnT in 2 weeks then it closes too. Otherwise I have to wait for next season to know...
I'm curious if anyone has this problem that uses a twin disk clutch?
Because if the problem continues that's one idea for a solution. My other idea is convert to auto and forever be done with missed shifts!!
I'm interested in your attempts to solve, and the results if you do. I'll post up when I can confirm my results.
