Power Radio Antena For 2002 Convert. Replacement
My power radio antena stuck in the up position and would not retrack when radio was turned off. Radio still worked but antena was always up and sometimes in the way when getting stuff out of the trunk. On the 2002 converts you have to replace the entire unit, motor and antena. On some other models you can get by with just getting an antena mast but on the 02 convert you have to replace motor and antena. The Chevy house wanted $190 for the unit and 2 1/2 hours labor at $80. per hour to install a new unit. I ended up getting a new unit in the box for $130 and had the old one out and the new one in in about 45 minutes. It's a simple job and you only need 4 tools. A x head screwdriver to remove both right rear tail lights (4 screws), a crescent wrench to remove the nut located on the antena mount located ouside on the right rear 1/4 panel. First put some masking tape on the crescent wrench so you don't scratch the two sided lock nut where the antena comes out of the body. Then a 10mm (2 bolts) and 8mm (2 bolts) socket to take the electric motor off the mount bracket and remove the mount bracket from the fram. Inside the cargo space (trunk) pull back the side wall on the right side, unplug the trunk light and then unplug the radio coax cable and electrical cable. This is all simple standup easy work. You don't even get dirty.
You'd obviously worked out that the mast was shot
Just in case anyone else has the problem where its just that the mast wont retract fully, it could be that theres a simple fix. Heres a How To:
How To Replace a Defective Telescopic Antenna
Now this is a simple mod and the OEM assembly with motor is $130+. You'll know you have the problem because the antenna won't fully retract
Parts:
Adjustable wrench
GM OEM Power Antenna Replacement ($13 E Bay).
Make sure the antenna is fully retracted and that the radio is off
Remove the antenna mounting nut located on the base of the mast on the outside of the car. If the mast is bent it may be necessary to cut off the old mast). If you can't all of the plastic cable out as one piece, (sometimes the plastic gets really hard and breaks into pieces then falls down into the motor), you can just pull the motor after you have pulled the mast out and get all of the pieces out. To do that you'll need to take out the outer right turn signal housing.
Turn on the radio and pull out the old mast and serrated cable completely out of the antenna motor. (Note which way the serrations on the cable are facing)
Feed the serrated cable of the new mast into the antenna hole and stop when resistance is felt. (about 12”). Make sure the cable is fed in with the teeth the same way the old cable came out.
Turn the radio off to lower the antenna until the serrated cable catches.. You may have to cycle the antenna a few times until the cable catches the gear mechanism and retracts into the antenna motor.
Replace and tighten the antenna nut into the mast base.
Turn on and make sure that the mast fully extends without binding. Clean the surface of the antenna to remove any adhesive etc.
10 minute job.
If you encounter a stuck mast here’s advice from the mast vendor:
You see the new "Retaining Sleeve" (silver, 2 inches or so, with slots) on the shaft of the new antenna mast, the original one is most likely a little corroded/frozen into the shaft of your antenna No problem : You are in need of what I refer to as the "snap and tap" technique of mast removal
Turn radio on and let cycle to as much extension as is currently possible
Take hold of the thickest metal mast section (closest to fender) with you thumb and forefinger about 2-3 inches above the top of the antenna shaft hole
Push the thickest mast section into the shaft (as much as it will go within that 2-3 inches)
Hold tightly with thumb and forefinger and Snap your Wrist upward.....you will here the mast bottom "tap" the bottom of the frozen in place retaining sleeve (what this is all about) Repeat this over and over again In-Snap-Tap-Repeat Short Firm Bursts of Energy Focusing the energy blow to the point of the tap This will free the retaining sleeve little by little till it comes out completely
Parts:
Adjustable wrench
10 minute job.
