lowering a stock c5
Old Nov 9, 2008 | 10:25 PM
Blk Btty C5's Avatar
Blk Btty C5
Default lowering a stock c5
alright heres the thing
im being told u can adjust and lower the stock springs up to an inch and a half
is this true?
and if so could someone gimme some info
thanks-
Old Nov 9, 2008 | 10:53 PM
clayton1's Avatar
clayton1
Banned Scam/Spammer
Do a search dude, more threads than you can shake a stick at
Old Nov 9, 2008 | 11:22 PM
Blk Btty C5
i looked i couldnt find anything exact, i saw opeple talkin about cuttin coils i dont want that
Old Nov 9, 2008 | 11:44 PM
happa's Avatar
happa
all you half to do is loosen the rear bolts until you have about 2-3 threads showing that will lower the rear. Tighten the front bolts until it stops and it will lower the front. Heres mine on bolt removed up front and longer bolts in the rear. good luck
[IMG][/IMG]
[IMG][/IMG]
Old Nov 10, 2008 | 12:02 AM
happa's Avatar
happa
This might help yea out https://www.corvetteforum.com/techti...D=27&TopicID=1
Old Nov 10, 2008 | 09:01 AM
Blk Btty C5
Originally Posted by happa
thank you very much this was a lot of help im probably gona do this in the next couple days, thanks man, also nice lookin car u got
one more question, did u just work on the bolts? in this thread u sent me it says the dude cut the bushings, just wonder if u did that?
Old Nov 10, 2008 | 11:01 AM
hotwheels57's Avatar
hotwheels57
Depending on your suspension type, you may realize 5/8" to 3/4" of drop with the oem bolts and bushings left intact.
You best read as many past threads on the topic as you can. There are pros/cons to doing the modification. You might also have problems with getting the front bolts to loosen/adjust, which some have discovered.
If you damage the bolts or threaded spring inserts for the bolts, you might end up having to buy a new spring. That involves removal of much of the front suspension components.
Old Nov 10, 2008 | 06:26 PM
happa's Avatar
happa
Thanks man, I took out the bolts, cutting the bushing will get you a little more drop. I took them out cause I was not happy on the height. I love the real low look. Good Luck!
Old Nov 10, 2008 | 06:30 PM
Blk Btty C5
u took them out completely? it says just to loosen them haha, im confused as heck, and the fronts are tighten i get that
now im jsut freakin out since that one dude said u could have problems, i thank him for tellin me so i know whats up, just confused
Old Nov 10, 2008 | 09:08 PM
happa's Avatar
happa
yea I took the front bolts out and I havent had any problems for 4 years and it hasnt gave me any trouble. The rear I got the longer bolts and adjusted them to the height I was pleased. If I was you, tighten the front all the way down, loosen the rear until there is only about 4 threads showing. drive it for a week and see how you like it, if you dont go to a forum vender who sells the lowering bolts for the rear. For the front either cut the bushings in half or take them out. Good Luck man and let me know if you need any help
To lowering a stock c5
