Well, took the car out to get it to learn the additional air flow coming in the engine...Rolling around 30mph, rpms about 3k or so, 1st gear..Punched with traction control off..Couldn't believe, the car started wheelhopping and do a slight whaletime..Didn't think it would do that...Amazing what a little more air flow will do for you. :cheers:
Re: Test drive after Halltech T1 install (Y2K253SS)
Get DOWWWN wit' yo' bad self, spunky!!! :cheers:
Feels good, huh:)
Now... when will you be ready for the heads and cam job ;) :p: :smash: :smash: :cheers:
Whenever I see a post where someone upgraded (?) to an 02' Z06 filter
lid. I think of the first time I drove mine after installing the Vortex.
If they only knew.... :D
Re: Test drive after Halltech T1 install (rschiltz)
Is the dyno # listed in your sig., with or without the Halltech?
On the last dyno day, a friend of mine let me use his sidewinder and my dyno numbers reflect the sidewinder installed..Were you thinking stock..I wish it was... :D
