Legendary Problem Solved....
Old 03-19-2015, 01:03 AM
  #181
JAY KOCH
JAY KOCH's Avatar
This forum rocks!!!
I have two fobs for my 99FRC, purchased new. The first fob quit several years ago so I used the second fob. The second fob quit working several days ago. It would sync but then lose the sync in a matter of minutes.
I opened up both fobs, re-soldered the chip in both and now they both work again.
Thanks for your willingness to share your experience and knowledge.
Old 05-11-2015, 07:53 PM
  #182
mrlmd
mrlmd's Avatar
This thread's been around for years, but my fob recently quit so I decided to fix it this way too. I had a good pair of loupes and sharpened a pin point tip on a small soldering iron, and at first the repair worked, then it quit again. I didn't feel like giving up, so I got one of those helping hands LED lit magnifiers from a site on Amazon for $3.96 which was the solution. Not only could I now see the joints better but it held the module so I could solder it effectively. Many of you expert solderers will have something like this, but for the rest of us, $4 was a great investment to get this job done. And you could use it to repair all your wife's jewelry and anything else small you have lying around.
Old 05-13-2015, 03:16 PM
  #183
Fastbird
Pro Mechanic
Fastbird's Avatar
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Sonofa. Top right on the main chip, sure as anything, the pin is loose. Gonna have to get a fine tip for my gun and reheat and see if it takes.
Old 05-13-2015, 08:52 PM
  #184
mrlmd
mrlmd's Avatar
Either file the tip down or put it on a grinder wheel and make a fine point. It worked for me.
Old 11-24-2015, 12:18 PM
  #185
paulrc5
paulrc5's Avatar
Here are a couple of pictures of the open solder joints I found on my FOB.
mre1974 (12-14-2015)
Old 12-14-2015, 11:18 PM
  #186
mre1974
mre1974's Avatar
I just had the exact same issue with my key fob. This forum is awesome.
Old 12-15-2015, 01:50 AM
  #187
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
EXCELLENT PICTURES!!!!!!!!!!!!
Old 12-15-2015, 09:34 AM
  #188
chasrg
3rd Gear
chasrg's Avatar
Default N/a
Originally Posted by chasrg
The Forum's stock just went up---the soldering fix worked on my 1998 fob that had not functioned for years---it works now--2/23/2015--CRG
------It is still working 12/15/2015--CRG
Old 12-20-2015, 03:43 PM
  #189
MrRenoman
MrRenoman's Avatar
Of the 3 fobs I had that didn't work; one of them had detached lugs. Soldered them back on and VOILA, it worked. Unfortunately the other 2 fobs I had that didn't look like that had detached lugs didn't work even after I re-soldered some or all of the lugs on the two chips. I guess 1 out of 3 is good. I'm going to look at the other 2 again. I did clean up the carbon pads, circuit board, etc. on a previous attempt to get them working. I don't want to give up on them.
Art
Old 04-08-2016, 01:53 AM
  #190
Skrilla
Skrilla's Avatar
I have to resurrect this thread because it actually worked. Thanks to all who posted this is a must read for any one with a 97-99
Old 11-11-2016, 11:17 PM
  #191
jhog01
jhog01's Avatar
Default Key fob
Took the fob apart those pins are loose will try and fix tomorrow. Thanks ill let you know if i melt them😀
Old 11-13-2016, 01:07 AM
  #192
chasrg
3rd Gear
chasrg's Avatar
The Forum's stock just went up---the souldering fix worked on my 1998 fob that had not functioned for years---it works now--2/25/15
As of 11/12/2016---still working---
Old 11-13-2016, 01:45 AM
  #193
avigar
avigar's Avatar
Folks, be sure not to let the soldering iron tip contact the solder point too long. Just long enough to let the solder meld properly into the connection. Otherwise, the prolonged heat from the tip may affect the components through heat transfer.
Old 11-13-2016, 11:46 AM
  #194
jhog01
jhog01's Avatar
Default Key fob
thanks will be careful
Old 12-22-2016, 04:50 AM
  #195
tmirisola
tmirisola's Avatar
Great post. Deserving of a sticky
Old 05-18-2017, 12:47 PM
  #196
Plentyfast
Plentyfast's Avatar
Worked like a charm
Old 05-30-2017, 09:05 PM
  #197
slovets
slovets's Avatar
Default Remote
Originally Posted by C599
Must be Xmas time. I figured out the issue with the famous key fob problem of it loosing sync with the cars. Turns out it's a problem with one of the chips coming detached from the circuit board.
When you open the key fob with the board facing you, look near the top right hand corner. There's a rectangle shaped chip, check the prongs. I checked mines both times when each of my remotes wouldn't keep sync with the car, each time it was loose.
I resolder it or you can even use permanent glue between the chip & board to hold it firm if you're not comfortable with soldering. Make sure the prongs have a good connection. Sorry that I haven't taken any pics, but it's pretty much straight forward.
Yeah, I know my atar is big, but I put it in at normal size & it keeps blowing up to the huge size. Yeah, I've resized it, lower resolution. I'll play with it some more later when time permits.
I will give it a try. They must be "cold solder joints" since my FOB looks just fine. Thanks for the feedback and will let you know the results.
To Legendary Problem Solved....
Old 05-30-2017, 09:07 PM
  #198
slovets
slovets's Avatar
  #199
slovets
slovets's Avatar
Old 10-08-2022, 11:05 AM
  #200
ripfree
Cruising
ripfree's Avatar
From Ripfree:
For disbelievers, here are actual photos of the stress cracks taken from my DIY repair on my 2000 C5 ragtop keyfob. I resoldered all 4 corners, and the contacts on the adjacent chip too. Sync now keeps. Note that this problem connection is right under the lock button. My theory is as the battery gets weak, people keep pressing the button harder. This places physical bending stress on the circuit board. That repeated stress causes the solder joints to crack. I've seen this before on other products. Sometimes you have to reflow the solder on an entire circuit board because the crack is not visible. On my other FOB, I had to solder the battery spring contacts to the circuit board because they wouldn't stay connected. That fixed the other FOB.
The following 2 users liked this post by ripfree:
B Neat (10-08-2022), Tusc (10-14-2022)
Quick Reply: Legendary Problem Solved....
