Need some Help with Modding My LS1!!
Old Jan 4, 2009 | 04:37 PM
stryderss's Avatar
stryderss
Default Need some Help with Modding My LS1!!
Whats up? I bought my 99 c5 about a month ago, and my HP goals for this car are 450whp. I need some help figuring out what mods to get me there without going forced induced, or straping nitrous. what can a ls6 intake manifold handle, and how much can one be had for? I am not against Forced Induction just wondering what it would take to get 450 on motor alone without No2? thanks for the help.
Old Jan 4, 2009 | 04:40 PM
lucky131969's Avatar
lucky131969
Originally Posted by stryderss
Whats up? I bought my 99 c5 about a month ago, and my HP goals for this car are 450whp. I need some help figuring out what mods to get me there without going forced induced, and nitrous. Would a ls2 throttlebody mount to a ls6 intake manifold? and what is the highest HP you can get before you would need to swap out the ls6 intake manifold? thanks for the help.
So you are saying you already have an ls6 type manifold?
Old Jan 4, 2009 | 05:11 PM
stryderss's Avatar
stryderss
lol No I do not have one, just wondering what the limitations are for it.
Old Jan 4, 2009 | 05:19 PM
MikeV's Avatar
MikeV
Hi Luke
Congrats on your new car. I hope I can help you reach your goal without wasting lots of money. Getting to 450 RWHP is expensive normally aspirated period! You have two problems in CA. One is emissions inspections that limit you to shorty headers and 91 octane gas which limits CR to about 11/1. Here is a senerio for N/A route.
AFR or equivlent heads with gaskets and ARP fasteners = close to $3K
Cam with new lifters /pushrods and rockers =$1K
Shorty headers with gaskets =1K
Underdrive pully with ARP bolt = $400
LS6 or better intake and new gaskets =$400 to $1200.
Tuning =$500
All prices are with out labor.
So your looking at about 6k minimum. You can buy an A&A S/C kit for about $4500 on special and have a real drivable car for less. I hope this helps. By the way the new heads should give you about 3 more MPG.
Mike V
Old Jan 4, 2009 | 05:30 PM
stryderss's Avatar
stryderss
hmm thanks mike. how do the ls2 intake manifolds stack up to the ls1 intake? and are there any mods i would have to do to make the ls2 intake and ls2 throttlebody work on my ls1?
Old Jan 4, 2009 | 07:08 PM
J.R.'s Avatar
J.R.
The LS2 intake and LS2 90mm throttle body will work. You will probably need to use a fairly stout cam to get 450RWHP out of a 346c.i. engine. By stout I mean something in neighborhood of a G5X3. The 205 AFR heads will really work well with this cam.
Old Jan 4, 2009 | 09:45 PM
willyfastz's Avatar
willyfastz
The LS2 intake is one of the worst LS intakes you can get. The LS6 is the better of the two and the stock TB will take you to your power level.
A set of properly ported 243 heads and a matching cam will take you to power level your looking for. The right 243's will out flow the AFR's and match the 3.899 bore better. If you spend the money on heads that are really efficient you can run less timing, less fuel, and a smaller cam than with the cheap heads that require more of the above. Which will make it easier for you to make power and pass emissions.
Old Jan 4, 2009 | 10:23 PM
black98c5's Avatar
black98c5
you will need a pretty stout H/C package to get you there and all the bolt-ons. I noticed that you're from California so you probably won't be able to go too big on the cam (224/228 114lsa or so) because of smog. It can be done but you will need the right combo.
AFR 205's, 224/228 114, LT's, CAI, Underdrive pulley and a FAST 92 should get you there if not pretty close. Good luck!
Old Jan 4, 2009 | 10:53 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
With a CA friendly cam, you will need a nice set of cylinder heads (AFR, Trickflow) and a FAST 92 intake.
Old Jan 4, 2009 | 11:17 PM
corvette_em's Avatar
corvette_em
What about the Jeggs High Performance december catalog that has the trick flow heads/cam packages for 500 and 515 HP? I personally was going to buy the 500 HP package for my stock 02 C-5
Old Jan 4, 2009 | 11:19 PM
corvette_em
stryderss's Avatar
stryderss
ok thanks for the info guys. what about a set of stock zo6 heads with upgraded springs? those are a 243 casting correct? and yeah i live in california so i would need to be within smog standards unless i register it in my home state of colorado (Im in the Navy).
Old Jan 4, 2009 | 11:20 PM
stryderss's Avatar
stryderss
Do you have a link to this? and what is the price on this?
Old Jan 4, 2009 | 11:33 PM
1slowFRC's Avatar
1slowFRC
You will need to port the ls6 heads and YES they are 243's. More than likely you will also need a FAST 92 Intake Manifold, possibly a Vararam Intake (Good hp when you are moving), and shorty headers, x-pipe etc.
My suggestion for you would to go the FI route and either get an A&A supercharger, ECS supercharger, or Maggie. This will give you a very streetable car that will definitely reach your 450 rwhp mark and will be much cheaper than a H/C/I route.
My .02
Old Jan 4, 2009 | 11:45 PM
1 BAD BURB's Avatar
1 BAD BURB
St. Jude Donor '06
tell us again why you do not want to go with a supercharger or twin turbo? a used blower from our for sale section will run you about 4-5K, plus install and tune, figure another 1K. you'll have a lot more power then a h/c bolt ons setup. you're not going to make 450 whp with h/c. if you do, its a heavy HEAVY build, which will probably run you up past 8K. at this point, your car will probably not pass CA inspection either and it will be a pain to drive on a daily basis.
your other option, buy a built 402 stroker motor. that'll get ya 450 easy!
i'd say go forced induction if u want to stay with the stock 346ci... do the research on it.
Old Jan 5, 2009 | 12:34 AM
stryderss's Avatar
stryderss
Im not against blowers at all just curious to see what it would take to get to 450 N/A. I had a SuperCharged cobalt so it wouldn't be new to me. I most likely will go that route. what supporting mods would be suggested/ mandatory for going with a blower. A and A is somewhat local too.
Old Jan 5, 2009 | 02:02 AM
corvette_em
No But in my catalog there are three part numbers if you go to summitracing.com (I thought it was jeggs) and type >
tfs-k306-485-460 ---485 hp
tfs-k306-500-460 ---500 hp
tfs-k306-515-460 ---515 hp
and you should find them...These are complete kits heads,gaskets,pushrods,camshaft,And rocker arms ---all matched!
ttyl good luck! ,chris
To Need some Help with Modding My LS1!!
Old Jan 5, 2009 | 08:41 AM
willyfastz's Avatar
willyfastz
I think those kits are flywheel hp.
Old Jan 5, 2009 | 08:53 AM
willyfastz's Avatar
willyfastz
Those kit's are pretty good, hard to deny the Trickflow heads.
The 243 H/C package will most likely out perform those kits. And they come with Ferara valves, Pac springs set up to match the cam. You can run your stock rockers with them, so no need to waste money on rockers. And we use custom 3/8" pushrods with all our H/C packages. The cams are custom spec'ed for each set up to match the car and the owners needs.
Old Jan 5, 2009 | 09:04 AM
WKMCD's Avatar
WKMCD
I had a nice H/C 90/90 setup on my 346. 230-236 112 +2 cam. You don't need a big cam to make good numbers. It's all about the combination of parts working together. My car made 460/425 and drivability was great.
