need quick help, hot in run source
Old Jan 11, 2009 | 01:31 PM
mcgilles's Avatar
mcgilles
Default need quick help, hot in run source
I need to find a good source of hot in run that is easy to get to and inside the car (BCM/console area) the factory connector for accessories is hot in run but not while cranking, I really need one that is hot while in run and during engine start as well. any good sources?
Old Jan 11, 2009 | 01:33 PM
mcgilles's Avatar
mcgilles
can anyone tell me really quick if the brown wire F7/C2 on the automatic HVAC control panel is hot during engine start? I can't remember if that thing turns off during start up. for some reason I think it does.
Old Jan 11, 2009 | 01:36 PM
lucky131969's Avatar
lucky131969
BCM area....piece of cake. Just use the accessory wire stowed in the fuse panel area.
I'll pm you my number
Old Jan 11, 2009 | 01:52 PM
mcgilles's Avatar
mcgilles
thanks,
but I'm pretty sure that wire is not hot during engine start, which would cause accessories to reset during engine start. something I don't want to happen. Maybe the only place to get it is behind the ignition switch...I'm not brave enough to start taping into those wires, especially with the column lock problems we have anyway.
Old Jan 11, 2009 | 08:15 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
ignition switch isnt hard i wouldnt sweat it, also for some reason i think the one in the kickpanel at bcm is hot in crank but i could be wrong
Old Jan 11, 2009 | 08:37 PM
lucky131969
thanks,
There are three accessory wires tape and stowed in the instrument panel electrical center area.
1 - Orange - Hot at all times, fused by minifuse 7
2 - Yellow - Hot with ignition on, fused by minifuse 11
3 - Black - Ground
Old Jan 11, 2009 | 08:45 PM
lucky131969
and the diagram.....
To need quick help, hot in run source
