Cruise Control Brake Switch Adjustment
99 convertible M6 - I am having what seems to be a relatively common problem - i.e. my CC is occasionally (actually rarely) turning off on its own when cruising. Irritating.... After searching this site, I tried the approach of holding the brake and clutch pedal up with the top of my foot and it seems to be related to the switch on the brake pedal. If I lightly touch the brake pedal, the CC turns off.
I have removed the panel under the dash and now have access to the switches on the brake pedal - and there are two.
Question 1 - Which switch is the CC cutoff?
The forum says the switch is adjusted by manually screwing it in/out. But the two switches are so close together that there does not appear to be enough clearance to spin either switch more than ~90 degrees in either direction.
Question 2 - How do I adjust the switch?
Looking at the switch installation, that would make me think that the switch should be moved closer to the brake pedal arm - delaying the actuation. However, when I look at the switch, the threaded portion appears to already be literally against the pedal arm with the brake at rest. So, if adjust this switch further forward, I am concerned that when the brake arm returns it will impact the switch - not just the spring actuator, but the actual switch body. I imagine this will quickly break the plastic switch body.
Question 3 - If the threaded switch body is already essentially touching the brake arm at rest, how will adjusting the switch body help this condition - i.e. delaying the switch actuation. And, won't this damage the switch anyway?
Thanks - any input would be much appreciated.
This is what the manual says about it:
Stop Lamp Switch Adjustment
With the brake pedal depressed, insert the stoplamp/cruise control switch into the retainer until the switch body seats in the retainer.
Note that CLICKS can be heard as the threaded portion of the switch is pushed through the retainer.
Slowly pull the brake pedal fully rearward against the stop until the CLICK sound can no longer be heard. The switch will be moved in the retainer providing proper adjustment.
Received 8,927 Likes
Slightly different from the Service Manual:
Cruise Release Switch Adjustment
Remove the LH I/P lower insulator panel. Refer to Closeout/Insulator Panel Replacement - Instrument Panel (I/P) Lower in Instrument Panel, Gauges and Console.- Ensure that the cruise control release switch is fully seated to the cruise control release switch bracket. Push the switch down toward the switch bracket; audible clicks will be heard while pushing the switch.
- Adjust the cruise control release switch. Grasp the clutch pedal and pull fully rearward against the pedal stop; audible clicks may be heard as the switch moves into the adjusted position.
- Install the LH I/P lower insulator panel. Refer to Closeout/Insulator Panel Replacement - Instrument Panel (I/P) Lower in Instrument Panel, Gauges and Console.
insulator panel removal
