2001 turn signal doesn't work sometimes
Old Feb 13, 2009 | 02:20 PM
d1278's Avatar
d1278
Cruising
Default 2001 turn signal doesn't work sometimes
Sometimes works, never know when it won't. Comes back to normal within minutes. Any ideas?
Old Feb 13, 2009 | 02:31 PM
byronhunter's Avatar
byronhunter
Cycle the e-flasher switch on and off about 100 times and see if that helps.
Old Feb 13, 2009 | 03:45 PM
oh1vette's Avatar
oh1vette
mine was the hazard switch...
Do a search, good instructions on forum to DIY
Old Feb 13, 2009 | 05:14 PM
vetterlatethannever's Avatar
vetterlatethannever
Mine was the hazard flasher as well. A little bit of shaking and its good to go!
Old Feb 13, 2009 | 09:15 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Since evenyone else suggested the hazard switch which was my first thought as well, I'll add my two cents worth to possibly a filament dying in one of the lamps.. forward or rear. There is a possibility that the filament will break, but bounce onto the broken edge and start working again briefly. I've also heard of people with lamp sockets that are getting burned or dirty.
Old Feb 13, 2009 | 11:56 PM
easyasone2three's Avatar
easyasone2three
Replace the hazzard switch.
Just do this: http://myweb.cableone.net/kd5fx/HSwitch/HSwitch.htm
To 2001 turn signal doesn't work sometimes
