WTB: abs delete 99 c5
Received 8,919 Likes
By the way other people do similar installations and don't have to screw up the car to get it done. Are you going to keep the car until it goes in the junk yard or are you going to sell it to some poor schmuck who ends up with a nightmare? Most people have a very low opinion of people who butcher cars to incorrectly install a mod.
Bill
mrr23 (11-12-2015)
i guess there is nothing else i can say in this thread.
it seems that no matter what i do or say, someone gets offended and wants to share their thoughts on how to make my car better for themselves. this topic went wayyyy off course (just like 99% of threads on here). my original question was if anyone knew of an abs delete kit. that's it! i don't give a **** about anything else anyone says about something even slightly off topic.
oh, and dougbnotsofresh.........looks like i hit the nerve. happy bull**** postings from your friends on the forum.
signed,
the cowardly internet gangster.
signed,
mrr23 (11-12-2015)
signed,
signed,
You won't be able to sell the car if you tamper with the system as it could make the car unsafe.
Unless you're an all out racer why tamper with the system.
Call here they prepare the T1 Vettes. http://www.phoenixperformanceinc.com/
mrr23 (11-12-2015)
mrr23 (11-12-2015)
[QUOTE=corvettebob1;1568994731]Quote:
Originally Posted by wheeelie
maybe i'll get lucky enough that one of those spikes goes straight up your ***!
Your so tough-talk this way in person or just real brave behind a keyboard?
[/QUOTE
This is what I love about this Forum - all the comradery.
However, the man has a point: it IS HIS car and he asked for an answer to a simple question; he wasn't soliciting opinions, like,you know, help me decide if I SHOULD do this.
Sometimes, its good to stick to the point; something our august elected officials in Washington do so well.
[/QUOTE
mrr23 (11-12-2015)
Thanks Donnie, no reason to get upset about anything on here, everybody is entitled to their thoughts, it's just the manner in which they do it.
[QUOTE=99 vett babycar;1569006581]
If you don't like or think what the OP or anyone else said, you don't need to go bash in his brains. This is why the middle east has never had any peace.
[/QUOTE
[/QUOTE
mrr23 (11-12-2015)
I think you should be able to do whatever you want to with your car! Its "yours". I choose to delete catalytic converters on my C5 and my WS6 TA too! Is it illegal or immoral or whatever?- Yes, but i do it because its MINE! Its my problem when i sell it to get it legal or to let the buyer be aware that it isn t emissions legal. I appreciate the advice i get on this forum but i don t pay attention to negative people that think that i should modify my cars like they think i should, not like i want it. ---In your case, i would try to get by with the ABS still working, but if you want(or need to) to temporarily(or perm.) disable it, more power to you! Sorry i don t have any info to help your quest to modify your car as u want, i just wanted to say what i did.- Jason
mrr23 (11-12-2015)
mrr23 (11-12-2015)
Overall, it's just modifying/making some lines and adding some splitter blocks. Anyone with any actual mechanical skill could handle doing it without a kit. One likely doesn't exist because it's easy and done very infrequently. You want to talk crybabies - what about someone needing a kit because they can't handle make a couple of custom brake lines?
mrr23 (11-12-2015)
mrr23 (11-12-2015)
I'm bumping this thread for a couple reasons.
1) I have 1997 with rusted out brake lines.... no one sells a kit and there are a million lines!
2) It will be MUCH easier to make my own lines like an old school hot rod. Proportioning valve up front single line to the rear split to each wheel.
Can I turn off all warning lights through hp tuners? hum Anyone ever done this?
mrr23 (11-12-2015)
mrr23 (11-12-2015)
#34
St. Jude Donor '15
#35
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The EBTCM is its OWN COMPUTER. It runs a Start Up Test on ALL of the routines that the BRAKING SYSTEM controls at power ON and all the sub components that are connected to the system i.e. Steering wheel position sensor, wheel speed sensors, ect... are also tested.
The EBTCM communicates the status of those test to the BCM through the SERIAL DATA BUS.
The BCM also sends out a STATE OF HEALTH (SOH) message to all the connected modules (PCM, LDCM, RDCM, EBTCM, SCM, Radio, HVAC, RFA, Air bag module, and the modules send out a SOH reply.
So,,,,,,,,,,,,,,,,,,,,, I you do anything to the EBTCM or Data Bus, the BCM will send out error and warning messages to the IPC and thus, you see all the messages and lights.
The EBTCM also connects to the PCM and can control throttle opening, reduce timing ect if excessive wheel spin is detected in normal mode TC on.
So,,, You cant just hook up HP Tuners or EFI Live and fix things. They can NOT interface with the BCM. The TECH2 cant change those parameters either because the EBTCM microprocessor is NON FLASH PROGRAMABLE. What's written is done by the people who designed the processor and its there to stay! GM does want people screwing with a SAFETY SYSTEM.
Same for your Throttle by Wire system. Its written inside the PCM where tuning can not rewrite or control. I know of one person who cracked that code!!!!
Bill
Bill
mrr23 (11-12-2015)
