C5 Hyperflash with LED's
Old 03-08-2009, 09:47 PM
lionelhutz
lionelhutz's Avatar
Default Fix for C5 Hyperflash with LED's
Hello,
I just changed my front corner lights and am going to install LED's too so they don't melt above the bulb again. It seems though, that the C5 can suffer from Hyperflash whenever the turn signal bulbs are changed to LED's.
So, I looked through the wiring diagrams to see what's going on. The flasher is part of the hazard switch so it can't just be changed. But, it seems to be pretty easy to bypass the flasher. There is a Pink wire which is key-on power. This pink wire feeds power to the flasher in the hazard switch. There is a purple wire which is the flasher output. This purple wire feeds the flasher signal to the turn signal switch.
To bypass the built-in flasher, it appears you just pull the purple wire out of the connector and then connect any typical electronic 2-terminal flasher between the pink wire and the purple wire.
So, anyone ever do this? Comments?
I'd also like to know where the "bypass harness" plugs in? They say under the column but I don't see where there is a useful wire plug under the column. I believe you can reach to the Hazard switch from under the column though.
Peter
Old 03-08-2009, 10:15 PM
RedWuken
RedWuken's Avatar
Here is the pre-wired one for sale: http://www.corvette-enhancements.com/c5_flasher_fix.php
The picture may help you out.
Old 03-08-2009, 11:44 PM
Camjamsdad
Camjamsdad's Avatar
Location: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
If you remove the knee bolster the harness is just below the key. You really can't miss it. The bypass harness is the easy way to go. The other fix involves removing the flasher switch. Then you open it up. There is an 8 pin IC chip. If you are holding the switch with the IC chip facing you and the chip facing more towards your left hand, you just cut or desolder and lift the 2nd pin from the left on the top row of pins. Sounds complicated but it's not. However doing this will also disable your bulb out feature.
Old 03-09-2009, 12:10 AM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
The bypass harness uses correct plug-n-play connectors and has an electronic variable load flasher. The flasher is not a typical thermal cheapo, but IS available in most any auto parts store should the need ever arise. The use of the harness also means the process is reversible should you ever want to.
The only (minor) drawback is that the electronic flasher is very quiet and barely audible when the radio is on, but of course the green indicator lights work normally so unless you're blind or never look at your IPC, you're OK.
Old 03-09-2009, 01:04 AM
lionelhutz
lionelhutz's Avatar
I'm going to have to look closer at the plugs under the column. It seems to me the bypass harness is just a flasher wired to replace the one in the hazard switch so it should not be hard to diy. Switched power to feed the flasher which then feeds that purple wire.
I've seen the Corvette Enhancements harness but $70US plus shipping will easily be $100CND once it gets here. It can't be that hard to wire in a $10 flasher and I can find better things to spend the other $90 on.
Peter
ArmchairArchitect (01-07-2018)
Old 03-09-2009, 11:56 AM
LoneStarFRC
Peter
With the bypass harness installed, your 4-way flashing emergency lighting is the ONLY thing still going through your original factory flasher when activated.
HTH
Old 03-09-2009, 05:24 PM
olftboy
olftboy's Avatar
I agree.... so I am posting to watch keep track of this thread.
Old 03-09-2009, 09:21 PM
spiral04
spiral04's Avatar
Old 03-10-2009, 10:11 PM
lionelhutz
lionelhutz's Avatar
Default DIY Flasher Bypass Instructions
Hello;
Here's how to do a flasher bypass.
Pick up an electronic flasher and a connector for it. I didn't see a flasher connector but there was a 3-wire headlight pigtail that would work just as well.
The flasher pictured is not suitable for use with all LED lights. Buy one from Ebay or Amazon that claims to be suitable for all LED.
Then, pull out the extra wire and you're ready to go. If you don't want to use a connector then get 2 spade terminals that will plug onto the flasher terminals to use instead.
The white connector is the one you need to get to. This connector is directly under the ignition switch. The picture is taken sideways. The end of the connector with the paper tags around it goes to the hazard switch and is the side you need to work on.
So unplug it.
Cut the purple wire. Cap off the end going to the hazard switch.
Connect one wire from the flasher to the plug end of the purple wire.
I splice the other wire from the flasher to the pink wire. After further examining the wiring diagram, I see you can just cut the pink wire the same as the purple wire.
My flasher had a X terminal and it said on the case to fuse the X terminal. So, I connected the X terminal to the pink wire and the other terminal to the purple wire. You can hold the wire ends into the other side of the connector to test the flasher before you install anything.
Plug the connector back in, install the flasher and test it.
If it works, put the car back together and you're done. If it doesn't work, you could possibly have the wires to the flasher backwards so carefully remove the side wire from the connector and plug it into the other side so you can turn the flasher around.
PS. If someone wants to they can take this and put it into the electrical sticky or copy it to their website for future reference.
Last edited by lionelhutz; 12-13-2014 at 07:05 PM. Reason: pink wire can be cut too.
The following 2 users liked this post by lionelhutz:
ArmchairArchitect (01-07-2018), Jason B. (06-28-2017)
Old 03-10-2009, 10:26 PM
olftboy
olftboy's Avatar
Beautiful.... I'm glad you got it figured out. I was just about to the point of starting on this project myself. Just finished fixing up my seat motors... and I was going to start studying the diagram. You saved me time and money. In the future, if I can do anything to help you... please don't hesitate to ask!!!!
Old 03-11-2009, 12:05 AM
nickwfd92
nickwfd92's Avatar
Great Info. Thank you for the info. I will be trying this out.
Camjamsdad
Camjamsdad's Avatar
St. Jude Donor '13
There you go.
Old 03-11-2009, 12:11 AM
JMc
JMc's Avatar
Location: "This is not a psychotic episode, but a cleansing moment of clarity."
Considering that the stock hazard/flasher switch is prone to premature failure ayway (at least a lot of them, including my own, have crapped out), bypassing the stock flasher to activate the turn signals is probably a good thing to do, regardless.
Old 04-06-2009, 09:57 PM
Nver2loud
Nver2loud's Avatar
Works awesome!!! thanks!! This should be a sticky, only takes about 5 minutes total to complete!!!
Old 09-12-2009, 12:13 AM
Jeffwilson34
Jeffwilson34's Avatar
Thanks for the tip,
after going through 2 sets of resistors I did this and it is cheaper (about $8.00), Faster (10 minutes at most), and easier than installing resistors.
The only thing I hated was cutting a wire on the harness but it can easily be fixed back to almost original with a connector and some heat shrink tubing.
Old 11-04-2010, 06:40 PM
Treeban
2nd Gear
Treeban's Avatar
Default Hyperflash
Previous instructions on how to install an electronic flasher are super. However, I am unsure how to remove the knee bolster. Removal of the two visible screws on the bottom of the bolster are easy, but it seems there are screws or something else holding it from the top?? Help...
Old 11-16-2010, 01:50 AM
GRNNREG
GRNNREG's Avatar
Default Knee Panel Removal Insructions
http://www.ls1howto.com/index.php?article=24
To C5 Hyperflash with LED's
Old 12-12-2014, 10:20 PM
old stingray
old stingray's Avatar
good info.to know.Thanks
Old 12-16-2014, 04:44 PM
GenerationX1
GenerationX1's Avatar
I just finished up this procedure and wanted to make a note that you don't have to cut the pink wire or purple wire for this to work, at least I didn't have to.
I just used vampire taps to tap into each wire and the blinkers work perfectly fine as does my emergency flashers. No hyper flashing whatsoever.
This procedure was no different than the one I did on my 03 Subaru WRX.
Old 01-17-2015, 05:10 PM
Silverbullet6spd
Silverbullet6spd's Avatar
A lot of help, I appreciate it. Cost me $15 at Autozone and everything works great.
Quick Reply: C5 Hyperflash with LED's
