Tire size
If they aren't you can have problems with the traction control.
Use this site to plug in front and rear sizes to make sure you maintain at least 1/2" difference in diameter.
http://www.rims-n-tires.com/rt_specs.jsp
I don't see where the problem is.
I ordered 265-40-17 front and 285-35-18 rear. The stock zo6 size 265-40-17 front and 295-35-18 in the rear. They are the same as stock z06 size except the rear will be 3/4 of inch narrower.
Where is the problem.
Also is this rear tire going to fit in my rear wheel well. And is the front going to fit.
But here's what you need to remember...the aspect ratio is expressed as a percentage of the tires width. ie, 265/40/17....the thickness of the sidewall will be 40% of the 265mm width.
So, comparing a 255/40/17, and a 275/40/17...the 275 is not only wider, but is also a taller tire, even though they are both 40 series tires. 40% of 275 is more sidewall than 40% of 255.
Using actual heights for the 3 tires I mentioned, you can see how much difference it makes:
255/40/17 = 25.0" tall
265/40/17 = 25.3" tall
275/40/17 = 25.7" tall
And the rear 285/35/18 will be 25.9" tall.
You'll be fine with the 265/285 combo...but as you can see, the 275 would be too close in height to the 285 rear, and has potential to cause some problems with unwanted traction control engagement.
I also have stock Z06 wheels and run 275/40x17 and 295/35x18. That combo has .4" difference. They fit with no problem.
he knows what he is talkin about
