Help!!! Air Conditioner not working
Old May 2, 2009 | 07:07 PM
jlf04's Avatar
jlf04
Default Help!!! Air Conditioner not working
I replaced the stock headers and took off egr. Now the ac turns on for about 1 to 3 sec. and shuts right back off again. I can't seem to figure out the problem... any ideas???
Thanks,
Jason
Old May 2, 2009 | 08:31 PM
byronhunter's Avatar
byronhunter
First, you don't have EGR. Check connections at the compressor and all the refrig lines. Then check for codes, you'll get some help.
Old May 2, 2009 | 08:43 PM
lucky131969's Avatar
lucky131969
Thanks,
Jason
codes?
Old May 2, 2009 | 08:53 PM
jlf04's Avatar
jlf04
no... there are no codes. vacuum line doesn't feel broken. pulled intake off twice just to check.. and nothing...
Old May 2, 2009 | 08:59 PM
lucky131969
Ok, so you actually checked to make sure there were not codes? Not just a SES light?
Is the compressor engaging? Did you disturb anything else. Why are you pulling the intake off? Even if you had lost vacuum, the compressor should engaged, you'll just lose mode control.
Sure you did not disturb the pressure switch?
http://forums.corvetteforum.com/c5-t...t-stay-on.html
Old May 2, 2009 | 09:11 PM
jlf04's Avatar
jlf04
we loosened the intake to remove the hose on the stock exhaust. so we thought that maybe we had broke it or it was loose... but nothing. I also checked the pressure switch and it is in place as well.
Old May 2, 2009 | 09:35 PM
jlf04's Avatar
jlf04
I just got in the car to go for a ride and these codes came up as history for the hvac
B0441 and B0361. I did look them up to see what they were but not to sure on what to do to fix the problem.
Old May 3, 2009 | 04:28 PM
byronhunter
Lucky ask "Is the compressor engaging?" IS IT????
Old May 4, 2009 | 11:03 PM
jlf04's Avatar
jlf04
no it wasn't. I found the problem. The New Headers melted the hose. The hole was hidden because of the heat foil on it. I replaced the hose and charged it up with some new freon and it's working great. Thanks for every body's help.
To Help!!! Air Conditioner not working
