Torque Tube rebuild parts, and disassembly / reassembly
Old 05-05-2009, 09:31 PM
Mike94ZLT1
Mike94ZLT1's Avatar
Default Torque Tube rebuild parts, and disassembly / reassembly
Hey guys, I bought a new TT out of an '02 Z06 for my 99 FRC. The TT has 17K miles on it, so it should be fine, but I want to make sure before I put it in. Where can I buy the necessary bearings, and I also want GM couplers. I have heard bad things about the quality of the BMW couplers, so I want to stay away from those. Also, do I need to get this assembly balanced? Thanks!
Old 05-05-2009, 11:00 PM
David A
David A's Avatar
Site Vendor RPM: http://www.rpmtransmissions.com/newproducts.html
Old 05-05-2009, 11:29 PM
Mike94ZLT1
Mike94ZLT1's Avatar
Originally Posted by David A
Thanks! Holy moly those things are expensive! I wonder if my bearings are OK with 17K on them...
Old 05-05-2009, 11:44 PM
ajg1915
Support Corvetteforum!
ajg1915's Avatar
St. Jude Donor '08
If the shaft isn't wiggling around on the front, you'll be fine.
The bearings could probably be bought a lot cheaper if you could figure out what size they are.
Old 05-05-2009, 11:46 PM
Mike94ZLT1
Mike94ZLT1's Avatar
I probably can. I live in the Motor City, I can get/find anything here! Part of me thinks I am wasting my time taking this thing apart, the other part of me says "won't you be pissed if you get it in, and its messed up?"
Old 05-05-2009, 11:58 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
If you got a good pair of snap ring pliers and a couple of flathead screwdrivers, it's not too bad to get a part.
Just remove snap ring and tap out from the front. Probably take you about an hour to do.
I know I would check it.
Old 05-06-2009, 12:11 AM
Goody
Goody's Avatar
Doesn't take much to get it apart. Really easy at any rate and I'm sure it will be just fine but at least you will know what you have.
I bought a set of snap ring pliers from Harbor Freight ($20)and they worked perfect.
Old 05-06-2009, 10:56 AM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Wheres the BEST PLACE to purchase an Aluminum coupler from???
While I have mine apart to change the clutch, I replacing the bushings and figured that I would go ahead and install an aluminum rear bushing.
Where have you purchased an aluminum bushing at a fair price?
BC
Old 05-06-2009, 11:05 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
BC
I got mine from Ecklers years ago.
http://www.ecklers.com/product.asp?p...dept%5Fid=2118
You could try LG or Breathless Performance
Old 05-06-2009, 11:39 AM
Mike94ZLT1
Mike94ZLT1's Avatar
Thanks guys!
I think I already have a set of snap ring pliers.
That breathless performance piece looks like a good value if its a rubber coupler AND an aluminum coupler for $130...
http://breathlessperformance.com/products/100-504.asp
However, I question its quality at that price.
Here is the LG one.
http://www.lgmotorsports.com/catalog...oducts_id=1605
I want a FACTORY rubber one for the front, or one stronger than factory. All I know is I don't want aluminum front and rear.
Old 05-06-2009, 11:56 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
I thing I have a few front "GM" 12mm couplers laying around upstairs in the my parts overflow.
I'll check on it tonight.
Old 05-06-2009, 12:02 PM
Mike94ZLT1
Mike94ZLT1's Avatar
I will gladly pay you for one, are they new?
Old 05-06-2009, 12:04 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Yes, I got run ou for the day, but will check tonight and drop you a PM.
Tony
Old 05-07-2009, 10:59 PM
Mike94ZLT1
Mike94ZLT1's Avatar
Guys who are running a rubber coupler in the front with an aluminum one in the rear... How much of an increase in NVH did you experience? Thanks!
Old 05-08-2009, 02:25 AM
Fastbird
Pro Mechanic
Fastbird's Avatar
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
Define wiggle please. Mine has some very minor play. Don't think it's related to my vibration issues, but never the less it would be definitive reason to have a look while it's apart.
Old 05-08-2009, 06:43 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
BC
Bill, last TT I refreshed, used the LG unit; I also bought a snapon torx plus for the 6 bolts on the coupler, seemed to be a better fit, keep in mind the bevel on the snap rings for the install
Old 05-08-2009, 08:46 AM
C4B4the04
C4B4the04's Avatar
Some wobble is normal. It has some play because of imperfections in the rubber casting I am sure. Mine had more out of round than I would have liked but has had no problems at all.
FWIW, I bought the Corvette Central couplers (10MM) and they WERE the BMW ones Even had a Guibo sticker/part number for BMW right on the bag. I don't think I'd trust it if I had a blower or twin turbos but works for a stocker. Bearings should be fine man, these were built to last. There was a post some time back that someone had all the bearings sized and listed by size number. Need to be double sealed I think (not into bearings that deeply but I think that means both sides have a watertight seal). Even posted a link to Amazon.com to get them!!! Yes they were substantially cheaper. Guess its what you decide is more valuable to you....your time to look it up or your money. Sometimes convenience of an all-in-one kit is worth the price, other times not.
Cassidy
To Torque Tube rebuild parts, and disassembly / reassembly
Old 05-08-2009, 02:42 PM
huttler
huttler's Avatar
Has anyone tried this carbon fiber TT replacement? For $1395 it really doesn't seem worth it, but I am curious to know how it worked out for anyone that's used it.
link
Old 05-11-2009, 02:44 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Hi Mike,
I looked for them the last couple of days but I can't locate them in all of the crap I have.
Sorry.
Tony
Old 05-11-2009, 10:24 PM
T_Vert
T_Vert's Avatar
I got my bearings from ebatmus.com. Exact same bearings as OEM and wy cheaper. Got the bushings for 17 ea. on ebay also.
Item # Description Quantity Price Total
6008 2RSJEM SINGLE ROW BALL BRGS 2 $28.74 RFQ
6007 2RSJEM SINGLE ROW BALL BRGS 1 $25.13 RFQ
ThomasR (04-08-2024)
Quick Reply: Torque Tube rebuild parts, and disassembly / reassembly
