Not Your Average Axle Leak
Old May 21, 2009 | 08:27 PM
americanexpress's Avatar
americanexpress
Default Not Your Average Axle Leak
SO i have been having a lot of problems with my LR axle seal leaking. i know it the seal and not the o-ring. i put a seal in it and it leaked again. when removing the fill plug i noticed a hissing sound, so i replaced the vent, and a 2nd seal. Still leaks. i am stumped. it has aftermarket axles(in the trans itself not the CV shafts) in it, so im going to go that route next. I used the GM seal driver and also checked the CV axles for any scorring/nicks/burs. wheel bearing seems fine and also when i spun the wheel when it was on jack stands couldnt see any significant play at the diff. please help me out. this this is suprising leaking quite a bit and i really dont want to drive it this way. thanks
Old May 21, 2009 | 10:11 PM
TEXHAWK0's Avatar
TEXHAWK0
Are you sure the leak is not coming from the vent? It is on that side right above the axle.
Old May 22, 2009 | 10:15 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
The side cover on the rear diff is the usual suspect. I did my axle shaft seals but also did the sealant fix on the left side rear diff cover.
Old May 22, 2009 | 11:18 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you took the fill plug out did you have a slignt vacuum or a slight pressure in the diff??? The vent plug allows pressure to excape but not to re-enter. When it cools down it keeps the diff under a slight vacuum and that helps to prevent leaks.
I would wipe down the entire differential and then examine where the oil comes from.
BC
To Not Your Average Axle Leak
