Tech II (need to correct mileage for an HUD install)
Received 1,194 Likes
St. Jude Donor '15
Do a search and you should find a thread or 100 that goes through exactly what you need. It really isn't a lot of parts, though.
I was looking at this old thread and realized that I did not ever post my results of swapping the small boards.
I swapped the boards and it did not work.
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hey vette.mix, I had to send mine to pacethis to have it corrected but if you want to do it I would get on it because he is selling all the equipment very soon. Oh the mileage is in the big board not the small one in the corner. I tried swapping the small one but it was no change. Oh by the way vette.mix, I just got done with the HUD install. went pretty good.
I also tried swapping the small green board at the bottom left of the cluster and it DID NOT change the mileage,i sent mine to get done to PACETHIS a while back and had great service and it was done correctly!
#33
#34
Are you still Active??
Greetings.. I"m attempting to reach you... please respond matthew@adealauto.com
#35
St. Jude Donor '15
Sorry, do not have the equipment anymore.
#36
Programming Cluster.
#37
Cruising
So it is clear that Tech II will not change the mileage.
If you are looking for answers to several questions like:
1. How to distinguish HUD from None-HUD capable Instrument Cluster?
2. How to find inexpensive & fast service to update mileage on new Instrument Cluster?
3. What are the Law requirements for someone to update the mileage?
4. What is it all about GM stating that Instrument Cluster should not be on its face for more than 15 min?
I posted it under another topic:
https://www.corvetteforum.com/forums...ansferred.html
My postings are #8 & #9.
Please note that replacing 1997-early 1999 Instrument Cluster with late 1999 to 2004 requires relocation of one bulb for airbag warning light from one location to another, there is a separate topic for that though the picture is no longer there
https://www.corvetteforum.com/forums...d-install.html
Here is the picture. Big thanks to whoever made this picture in the past!
Big thanks to whoever made this picture in the past !
Please note that there is also a good YouTube video (not mine but by TM) how to swap remove and install Instrument Cluster without entirely removing dashboard and pain with glove box. Just remember that video talks about one cable while it is correct for None-HUD for HUD Instrument cluster there is an extra cable going out to HUD.
Happy HUD Projection!
May the force of hologram be with you, keep your eyes safely on the road knowing thy speed!
#38
BlueAngelVet, check out this thread, I think you'll find the answers to most of your questions here.
Good luck... GUSTO
Good luck... GUSTO
#39
Cruising
Hi Gusto14, It is funny you say that because it is the same link I posted the answers myself there and I just wanted to provide the link in case someone is looking for the answers under this topic: "Tech II (need to correct mileage for an HUD install)"
You are just quoting the same link that I did above.
That means I am doing something right.
