No woodruff key on the stock crank pulley/balancer ?
So I'm in the middle of replacing my crank pulley (and by the way I sincerely regret ever starting this job, what a friggin nightmare !!!!!)
Anyway, I'm replacing it with an underdrive pulley which comes with a slot for a woodruff key that I was expecting to find after removing the old pulley.
Anyway, the stock pulley has nothing, the surface is smooth, what gives here, I've never ran across this on a crank before.
The new pulley has timing marks of course, so without the woodruff key how on earth are the marks lined up ?
St. Jude Donor '09-'10
Thats correct. You will want to PIN your new balancer. The woddruff key is only good if you have an aftermarket crankshaft. Mine has TWO pins...
You will see one other place where it used to be pinned with on OEM balancer.
You don't "have" to pin it, but while its off it is a good idea. Since your new pulley has a keyway milled in it (Powerbond or ATI?), you can use the ATI kit to pin it and it will be much easier to remove/install later if you need to. The ATI kit installs the pin perpendicular to the crank snout. You can see where mine is drilled in the photo, a pin goes in the hole when installing the pulley.
I am speechless right now, I am so mad I can barely think. I have never, NEVER seen anything like this. Why in God's name didn't they simply install a key like every other vehicle that has ever been created in the history of automobiles has ? They actually expect the person to drill some kind of holes at the end of the shaft in order to install this ? What about a new stock pulley, how on earth do the marks get properly lined up ?
The instructions by the way, just says to bolt the pulley on and torque, doesn't say anything about the key slot, or the fact that your car doesn't have the key to begin with.
Absolutely beyond belief.
As said earlier, you don't "need" to drill anything to install your pulley or a stocker for that matter. If you hang a hair dryer or huffer on however, it is highly recommended to drill.
What am I missing ?
So to get the timing marks lined up what would be the procedure ? Find TDC, then install it according to the correct timing, i.e. 5 degrees BTDC or whatever it should be at ?
SG Lou (08-08-2018)
Again, the marks are not needed. Timing is not referenced there. The PCM determines engine timing.
It just provides the option. My ATI has the timing marks, which I aligned as best I could by eye when I installed and pinned the crank. As for the stocker, no keyway in the hub. It is an interference fit. Also, don't use a bolt to pull it on, if you don't have the correct tool or a reasonable facsimile you will damage the threads. Here is the tool I made for installation. There are several steps involved as well if you are using a "new" stock bolt (old one shouldn't be used).
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The PCM reads crank and cam position from sensors, yes.
There is zero need for any external pulley markings though, because there is not a thing you can do to adjust spark timing from within the engine bay.
If you have a laptop and some tuning software, you can adjust the values within the half-dozen or so timing tables within the PCM logic...but the PCM is always in direct control of firing the plugs.
