Lowering Question (I did search)
I tried to lower my car on stock bolts. I did not cut any bushings. The back is noticeably lower how ever the front looks the same. So I want to go lower and have searched for a "how to" on lowering with stock bolts and there are just so many threads that aren't very clear on the EASIEST way to drop the car. So could someone please provide me with a link to a how to, or provide step by step instructions on the simplest way to lower the car. Whats the easiest way to remove the front bolts?
I have lowered all of the four C5's I've owned front and rear myself...
You should be able to get about .75 inch on the front with the bolts in...
It is reversed on the front, did you tighten the bolts in the front with the 10mm (from memory) so the bushing is tight with the leaf spring?? You want the lower part of the bolt closer to the lower A of the suspension...
This is the procedure I used to take out the stock front bushings and in
stall after market adjusters w/out bushings. http://www.corvetteforum.cc/techtips...D=90&TopicID=1 I can't get this to come up,Sorry.
Try your search again because I think there are some really good picture instructionals.
Nevertheless, if it is turned all the way up to the spring and you want it lower then yes, you will need to pull that bolt out.
If that is what you want to do, then there are instructions here...
