Low beam headlight not working
Old Jul 15, 2009 | 09:01 AM
rlgreen@vwb.com's Avatar
rlgreen@vwb.com
Cruising
Default Low beam headlight not working
I have replaced the low beam bulb on the drivers side and checked the electrical connection.
The other side works fine and both high beams work. Any ideas?
Old Jul 15, 2009 | 10:41 AM
lucky131969's Avatar
lucky131969
What does "checked the electrical connection" mean? Does that mean you have verified that you have the following:
1) Fuse #10 in the underhood electrical center is not blown
2) 12 volts at the connector with the headlights on - pin C- yellow wire
3) Ground at the connector - pin E - Black wire
