header install guestion
Jul 19, 2009 | 02:42 PM
2000frc factory exhaust manifolds came out easy, shortys hard to get in on left side. any help?
Jul 19, 2009 | 03:32 PM
Left side? Drivers or passanger side?
Most people will undo the motor mount bolts from under the front cradle and then rock the engine by jacking it under the oil pan.
Tony.
Jul 19, 2009 | 03:42 PM
header question
need help on left side
Jul 19, 2009 | 03:51 PM
What is the left side dude? Driver or passanger side?
Either way, try and unbolt the motor mount nuts from the underside of the cradle, jack the engine up and slide your header in.
Jul 19, 2009 | 04:17 PM
It might help if you're a bit more specific...type of shorty headers, where they're obstructed, define "left" side, etc.
You could also contact the manufacturer...
Jul 19, 2009 | 04:26 PM
Quote:
Originally Posted by
Speed Density
Tony.
Left side is the drivers side
Jul 19, 2009 | 04:57 PM
Put my B&B Tri Flo left side shorty in from underneath.
L or R side of vehicles are always defined by sitting in the drivers seat. Standard auto mfgrs. terminology.
Jul 19, 2009 | 06:04 PM
Did you remove the serpentine belt along with the alternator? This allowed me more room to work with. I removed the belt, alt, coil packs, and valve cover. Also fuel line removal also helps.
Jul 19, 2009 | 08:22 PM
the dreaded left side
thank for the help. did have the belt and alternator off , then b&b's put up a good fight but after I removed the center nut on the m mount and jacked her up the shorty fell in
Jul 19, 2009 | 08:27 PM
Redhawg
Really? Because if your standing in front of the car the left side is the passangers.
Jul 19, 2009 | 08:48 PM
Speed Density
That's a joke right.?....are you a girl?
Jul 19, 2009 | 09:06 PM
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
lucky131969
maybe standard girlie talk???
Jul 19, 2009 | 11:45 PM
I have been working on cars for over 40 years and I was taught the right side is the passenger side and the left side is the drivers side. I have never had a problem using this analogy.
Jul 20, 2009 | 12:55 AM
In all the years I've working on cars it never occurred to me that the left side could be the right side.
Jul 20, 2009 | 10:23 AM
you shouldnt have any problem fitting them from the bottom
Jul 20, 2009 | 10:24 AM
Speed Density
Nope..driver side= left side......passenger=right
