ABS, TCS, AH, C1243 issues, please enter and give the grave analysis
FYI, tonight I put the old unit back together and re-installed it so I could drive the Vette around while the other unit is in shipping. Unit passed it's startup test both power cycles, but when I checked it with a hard stop, the ABS engaged, then tripped off line just like it used to.
So, cycling the motor, in my case, didn't change anything.
I'll let you know when I get the replacement installed.
Have a good one,
Mike
Have a good one,
Mike
Mike,
This may sound a little crazy. But it doesn't cost anything and could be your problem. Do you run wide wheels? I found that my CCWs would rub if I went lock to lock.
I strated getting the same codes. Thought the worse. I was wrong. I got under the car an I followed the wires from my wheels sensors to the unit and found that my right wheel had rubbed the wires and that there was one spot where the wire would occasionally ground. Replaced those wires and poof... No problems.
I hope this is what you are dealing with.
Final Update
Last night I got the replacement unit (pulled from a wrecked '99) installed. My wife and I did a good manual bleed (tried the pressure bleed but wouldn't push the air through). The brake pedal felt normal, perhaps even better than before, and the shop manual says that an automated bleed is only required if the pedal stays mushy. So I took it out for a test drive and got the system to activate on the front tires. I activated the rear tire solenoids by making the rear step out at an intersection and the AH system engaged.
After all that was done the pedal felt just the same as before, so right now I'm not going to go to the time, effort, and cost of having a Tech 2 bleed performed.
Have a good one,
Mike
Have a good one,
Mike
"Final update" Post-Mortem update would be nicer.
Hello VetteDrmr ! I have a c1243 code on my 1998 Bonnie. I ran into this thread and was impressed by the talent on this forum. I did the same as you. I have checked for good ground connections. I opened the Abs unit and everything looks ok. I even cut the plastic covers off the internal Bosch relays(the contacts looked good) I cycled the pump motor with a jumper wire 15 times for about 3-5 seconds it seems to start and run ok. My thoughts are that the motors amature or brushes must be worn. My Factory service manual says; the unit is not serviceable and will leak if put back together......... fine. But I am curious, if you still have your old part could you dissect it and report back?
Red92,
Sorry, that unit has been, um, "recycled". Don't know that it matters, though; I don't think you could get the motor disassembled without doing so much damage as to make the repair moot.
Good luck getting yours fixed, and have a good one,
Mike
Mike
Ok I'm Bringing up an old post -
The Fact is anyone of us that own a pre 2001 & has this issue , ur pretty much SOL ! U can bet that if I would have known what my options were on fixing this 1243 , I would have flipped the Bird at the Corvette dealer & I wonder how many c6 s are we gonna see in the next few years thathave these same problems that GM wants to Shut their eye to ??? Better be buying something' besides a GM if u gotta have ABS ! My rant!
