Normal oil pressure
Old Aug 19, 2009 | 07:02 PM
guido7834's Avatar
guido7834
Default Normal oil pressure
What should be normal operating oil pressure on a 2002? My Dial gauge is pinned at 80 psi and the digital gauge reads 130.
Old Aug 19, 2009 | 07:35 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
SEARCH
there are 10 threads on the first page that explain your problem
it's the sensor. they're prone to failure.
Old Aug 19, 2009 | 07:42 PM
SiL3NtXWS6's Avatar
SiL3NtXWS6
Your oil pressure sensor, back of the intake, is bad. Sorry. You can cut the cowl or remove the manifold (which isn't as bad as people think it is.)
Old Aug 19, 2009 | 08:50 PM
guido7834's Avatar
guido7834
Sorry, I didn't look at the forum before I posted my question. Thanks for the replies. Is it something that needs to be replaced immediately?
Old Aug 19, 2009 | 08:53 PM
guido7834's Avatar
guido7834
ttt
schpenxel's Avatar
schpenxel
St. Jude Donor '15
I went 2 years without replacing mine.
It's certainly not a bad idea as keeping an eye on oil pressure is a good idea. But the chances of it actually hurting anything are slim at most.
Old Aug 21, 2009 | 04:56 AM
waddisme's Avatar
waddisme
Unless you are tracking the car it shouldn't be a problem. Then again, it seems like the computer wouldn't let you drive car if it thought it was a problem.
To Normal oil pressure
