Battery: which is best, AC Delco or Optima ?
Former Vendor
We have used Optima's for many years with great success.
$140 shipped - Optima Red Tops
$145 shipped - Optima Yellow Tops
http://forums.corvetteforum.com/c5-p...5-shipped.html
Seth
Seth
I have good results with the Exide Orbital, it is a AGM, so no acid to run out. You can get these at Sams Club, Costco, and BJ's to name a few. I have a local auto parts house carrys the Orbital. I have had one for the last 4yrs. with no problem. I also have 4 of the Orbital in my boat for the last 4yrs as well. I am a believer.
Ed
Red top is the biggest **** on the market.
I had one and had to warranty them every 6 weeks. Went through 7 BATTERIES!!! after that i through it in the garbage and got interstate
My 04Z still has the original battery in it and when it goes I will replace it with the same. Before I spend 140 dollars on a optima someone needs to tell me why.As a matter of fact the Delco has to be a great battery because I drive my car rarely so it sits sometimes weeks without starting and never had a issue and I don't use a tender.
But if you have top post or battery in the rear it is not an issue.
Me and two of my vette buddies had to replace our optima battery. we all went to a sears die-hard. a lot of batteries now have the no leak sealed case. buying an optima is a waste of $$
I have been doing searches and reading, so it looks like location of the posts is what causes the leaking. Where are the posts on the AC Delco Professional?
if I am reading correctly...
this is good
and this is bad, right?
this is good
Correct the side terminal are what I was using when they did leak. The dealer that sold the battery told me they would not warrant leaks so I bought an optima in 02. The optima failed in 04 but I still have that same battery now going on 7 years use. I have noticed that if the car sits for a week it cranks a bit slow. If I use it every 3 or so days it cranks normal. After the first cold morning start it always starts normally.
#33
My ONLY desire is to have a battery where there is no chance for a leak. Is Optima my only option? I have went through the battery leaking nightmare in 2001, and can't afford for it to happen to me again.
#34
My Optima is almost 10 years old (installed 2001), and just starting to crank slow this past Thursday when she came out of storage. Plus I noticed some white flcky stuff on the black terminal, so I am going to change it
Now I won't use anything but Optima. I however did call optima and asked if their red top batteries were warranted against leakage. Their answer. NO! So even with Optima I still check. But after 7 years still no leakage, so it has to be better than the OEM Delco.
#35
#37
Exide Orbital is even more expensive that the Optimas.
Looks like Optimas went up in price too, I was looking at my receipt from 2001 and the Optima Red Top 75/35 DT cost me $109.99 plus tax (plus $7 core). I might spring for a yellow top this time after reading about down times. After reading many posts bashing new Optimas quality, I might get a Diehard Platinum
How hard is it to change a battery yourself? (any write up), I want to go in there and do a thorough cleaning along with put in a battery pad.
#38
It appears to be quite simple:
1. disconnect the negative battery cable
2. disconnect the positive battery cable
3. remove the battery hold down retainer bolt and retainer
4. remove the battery
Battery hold down retainer bolt is tightened to 13 lb ft.
Battery cables are tightened to 11 lb ft.
