How do I replace my BPMV
Old Oct 21, 2009 | 01:28 PM
jazzvette's Avatar
jazzvette
Default How do I replace my BPMV
Here's the codes I'm getting from the DIC1261,1263,1265,1267,1271,1273,1288. I guess I can say that this pump has had it. Will I have too bleed the system when I replace the BPMV? Need help tired of having my cluster lite up with warning lights and my traction control system not working properly.
Old Oct 21, 2009 | 03:14 PM
87SAM's Avatar
87SAM
Yes, and not only do the brakes need bled but you need a Tech II to bleed the pump. I had a shop change mine for less than 200 dollars. Have you troubleshot the system to see if it is indeed the pump? Could be a connection or wiring issue.
