PCV on LS2 Throttle Body?!
Old Oct 30, 2009 | 01:23 PM
Lunchbox_Killa's Avatar
Lunchbox_Killa
Default PCV on LS2 Throttle Body?!
I recently installed the 92MM FAST Intake with the 90MM LS2 Throttle Body. Appears there is no PCV connection on the LS2 throttle body itself, and I now have a disconnected one on the right side.
The installation instructions said nothing about this modification. Am I missing something, maybe the point? Should I just cap this off seeing as its the fresh air return.
Any help would be appreciated, wanna start her up.
Old Oct 30, 2009 | 01:50 PM
Brandon619's Avatar
Brandon619
No you are thinking of the coolant lines. The LS2 TB has no previsions for the coolant lines
