C5 X-Pipe
thanks, john
I am an old schooler myself, been with the new stuff since I bought my 98 in 98. I am up to doing my own computer tunes with HP tuner software! Takes some time to learn but really neat stuff!
As I recall low end Torque was enhanced... I say enhanced because I don't remember any numbers!
They discussed how an X-pipe works, then ran a car on a dyno, and the strip with:
1) open headers
2) mufflers & pipes w/o a crossover
3) mufflers and pipes with an H-pipe
4) mufflers and pipes with an X-pipe.
These are the results:
a) Test Vehicle / 1970 Olds 4-4-2 w/350 block and modified
b) Where first seen / NASCAR guys began using X-pipes
c) X-pipe design theory - "By running the two exhaust pipes together in this fashion, the alternating pulses in each bank can work to create the same type of scavenging action in the other."
d) Works best on a V8 engine running 300-500 hp because the volumetric efficiency is not as great as on a 700-800 hp V8 engine.
e) Dyno pulls:
1) Open header
430 hp @6850 rpm, 384 lb-ft @5600 rpm
2) 3" exhaust pipes w/Straightline mufflers and no crossover
412 hp @6650 rpm, 371 lb-ft @5600 rpm
3) Same setup as #2 except with an H-pipe
419 hp @6600 rpm, 378 lb-ft @5600 rpm
4) Same setup as #2 except with an X-pipe
428 hp @6600 rpm, 391 lb-ft @5600 rpm
Strip tests:
1) Open header
1.65 sec 60', 10.885 sec @123.89 mph
2) No run with the exhaust system w/o a crossover
3) Exhaust system w/Straightlines and full pipes and an H-pipe
1.55 sec 60', 11.007 sec @121.33 mph
4) Exhaust system w/Straightlines and full pipes and an X-pipe
1.62 sec 60', 10.897 sec @124.13 mph
This car, which used to run open headers at the strip, now runs with a dual exhaust system with an X-pipe. More details in the magazine, naturally, but very interesting, I thought.
And yes, the article discussed mounting the X-pipe far forward in the car, just after the headers, to maximize scavenging.
Ed
Too cold for golf, so I'll expound a bit here:
If you're going to leave the engine internally stock (see my last paragraph), then I think you'd get just about all there was to get in the exhaust system by just going with a good 2 1/2" aftermarket full-length system, such as the LG streets, and any good catback that suits your sound requirements.
Starting up front and working back, you could:
1. Install a good cold-air intake system, the Vararam gets great power reviews, the Callaway gets the quality award. The Blackwing is beautiful, affordable, and easy to install, and works well with open foglight shrouds when moving, but does heat soak at red lights.
2. The Vararam uses the fog light openings to take in air, but if you install another intake, go ahead and open the fog light areas like the Z06 to get cool air into the engine compartment.
4. Everybody has a water temp/thermostat comment, but whatever temp you want (194/180/160), you will need to get the fans programmed to match the thermostat. Your tuner will do this when he dyno-tunes the car.
3. You have the larger MAF, no real restriction there. The Z06 has the air-straightener removed, and some guys do that on the LS1 hoping to gain a couple HP. But some guys have fits with lean codes when they do it in conjunction with a cold-air-intake.
4. You could port the throttle body - maybe only a couple of peak HP, but you should get a bit of torque in the mid-range and improved throttle resonse in that range. I just installed one, definitely jumps quicker when you hit it. No need for a big aftermarket TB on a stocker.
Someone mentioned the throttle body coolant bypass; well, why not. Buy a little hose splicer for 98 cents and do it.
5. You have the Z06 intake manifold already - it's a great piece for a stock engine. An expensive aftermarket piece might get a couple more HP, but would be prohibitively expensive for the gain seen I think.
6. Good longtube 1 3/4" headers, with high-flow cats and integrated X-pipe. And pick any aftermarket (or the Z06 ) mufflers, but watch out for resonance; some can be deafening with headers and hi-flow cats.
Don't know if 3 inch would help a stock engine; might just kill some torque rather than helping.
7. A 25% reduction harmonic balancer is a great addition; we've sen about 5HP claimed, and it makes the engine feel a bit "zingier". Reduces load on accessories also, with no downside that I have observed.
BUT, if you're gonna spend 2 days installing one, you're 70% of the way to putting in a cam. So nobody does a balancer unless they are doing a cam also (hint, hint).
8. The dyno-tune of course. The C5 has no "chip' like the old days. The computer has flash memory, and is just electronically re-programmed by your friendly tuner. There are several good hand-held units that you can purchase and plug/play a reprogram. But, I think if you are making some mods, then going to a live tuner is more rewarding, and a lot more fun. And you get the dyno sheet to prove what your new power numbers are.
9. Rearend gears and/or high-stall torque converter. I didn't notice if you had an auto or a manual. But either way, going to lower gears makes for a lot of fun and quicker acceleration. Torque converters can turn an auto-tranny Vette into a holeshot monster.
If you do all the above, you could reasonably expect maybe 40 more horses at the wheels (your numbers may vary).
Of course, all the above is assuming you will leave the internals alone - which you probably will not once you get the bug. A stock LS1 is just dying for more cam; there's 40 more HP just waiting to get out with even a mild cam, that would be totally driveable, reliable, and smooth.
DG
Very nice write up Wrench. I am working on some of those mods my self. Early LS1 users might see a curious "dip" in the dyno graph at 5500 like I did. It appears our stock valve springs are a little weak on the top end. I am replacing them this weekend.
