Do I need a tune after header install?
Old Jan 25, 2010 | 01:49 PM
2_99_c5s's Avatar
2_99_c5s
Default Do I need a tune after header install?
I'm planning on installing my OBX LT headers and Borla straight pipes. It's a '99 and also has a CAI, mass airflow sensor, and larger throttlebody. Will it need to be tuned immediately or can I wait a few months and tune it down the road?
Old Jan 25, 2010 | 01:53 PM
lucky131969's Avatar
lucky131969
The short answer is "yes" you can....but why?
Why not just wait, install and tune immediately You are just leaving HP on the table without a tune... not to mention driveability, gas mileage, etc.
Old Jan 25, 2010 | 02:03 PM
jrose7004's Avatar
jrose7004
Yes you'll need a tune.
Old Jan 25, 2010 | 02:26 PM
Daddyrama31's Avatar
Daddyrama31
Old Jan 25, 2010 | 02:46 PM
2_99_c5s's Avatar
2_99_c5s
My main reason for wanting to wait is $$$ for the tune. I have the headers and am just waiting for the plugs and wires to come before the install. I am a broke college student who spends all of my money on my toys (2 vettes and a bike). I'm anxious to install the headers but won't have money or time to make it to ECS for a tune for a little while. My main concern is: Will installing the headers and driving regularly without a tune cause any damage to the motor?
Old Jan 25, 2010 | 03:09 PM
lucky131969
Obviously you are not that "broke", if you have two vettes and a bike......
I can't say I was much different when I was younger(with respect to patience).......I guess patience comes with age. The other part that comes with age is experience. While a header install is pretty straightforward, you may run into unforeseen complications, which will require more funds.
When you start asking questions like" will I damage my motor", simply because you are impatient, you really need to take a step back and ask.......do I have to do it right now?
Good luck with your choices...
Old Jan 25, 2010 | 03:22 PM
Blow Torch's Avatar
Blow Torch
Lucky makes a Good point!
But No, you will not hurt your engine by driving it. The computer will read the small change in AF made by the improvements in air flow and adjust your fuel trims accordingly to get the proper AFR at cruise. That's what it was designed to do.
The only issue you might have would be at WOT, which is a SET enrichment amount. In reality, however, you will proably be running a little rich at WOT, since the PE enrichment factor is actually added TO the positive fuel trims. To be safe, however, don't beat on it until you take it for a tune.
What the guys are telling you basically, is that you won't get the full benifit of your mods until you do take it for tuning.
Old Jan 25, 2010 | 05:22 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Plugs and wires wont make one rats azz of a difference it that's what you're REALLY waiting for.... ($$$)
Get the tune, whether you've had headers in the first place or not... a tune will help a stock or modded car.
Old Jan 25, 2010 | 07:30 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
you can wait.
I did all the bolt ons and didnt have the car tune for a year. It was when the cam was installed that I had it tuned.
Correct, you are leaving power on the table not having it tune. But if your talking about drivablity issues, you shouldnt have any.
My personnel experience was I had no issues and I did everything from the vararam to the GHLs. Will it run better are a tune, Yes.
Old Jan 25, 2010 | 08:00 PM
KrenzyRyan's Avatar
KrenzyRyan
Have you guys seen MPG increases with tunes?
Old Jan 26, 2010 | 09:38 AM
Blow Torch's Avatar
Blow Torch
Yes; With the timing and VE tables optimized to the new "better breathing" motor, you should get very good MPG
Old Jan 26, 2010 | 09:48 AM
2_99_c5s's Avatar
2_99_c5s
I got the plugs and wires because the car has 80k and it seems like when you pull the headers is a good easy time to swap the plugs
Old Jan 26, 2010 | 11:06 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
You can wait until your ready, like others have said, it's not optimal, but you will not cause any damage.
We will be here when your ready, and thanks in advance!
Old Jan 26, 2010 | 04:21 PM
phils C5 vette
I dont recall any decrease in MPG after the bolt ons without the tune, but after ECS installed my first cam ( TR224) and I had the car tuned, I did have improved MPG highway. ( city always goes down hill the more fun the car is lol)
I went from 28 MPG on the way down to their shop to 32 MPG home. It was a 2 hour drive down the turnpike, So I think that was a good test
Even now with a larger cam and heads with gears and lots of tuning, Im still at about 25 highway, and average about 18MPG
Old Jan 28, 2010 | 09:34 PM
RDnomorecobra's Avatar
RDnomorecobra
that thing is gonna be loud. I bought a used 03 z with stock manifolds and cats. he removed the axle back and put those Borla pipes on. could not carry on a conversation in the car. I put Borla's x-pipe with integrated muffler in to replace the stock H pipe. little better and necessary to pass inspection in PA.
Old Jan 28, 2010 | 11:14 PM
vodas00ss's Avatar
vodas00ss
NO! You dont need a tune after headers. In my old 2000 ss camaro I did headers with no prob drove it for several months, then did heads, cam, and intake, clutch all at once, It drove like **** for a week, then the car figured itself out. I drove the car like that until i had the time and to take it to tsp to have it dyno tuned, the car only gained 9 hp over what the cpu had done itself. And im pretty sure tsp is a respectable place to have your car tuned. Car still runs like a beast...thanks MS3!
Old Feb 21, 2010 | 12:19 AM
oakvillec5's Avatar
oakvillec5
To Do I need a tune after header install?
Old Feb 21, 2010 | 06:13 AM
gcolella's Avatar
gcolella
Default Money well spent!!
Take it to ECS you wont believe the difference.
Old Feb 21, 2010 | 11:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I installed LT headers, High flow Cats, Complete 3" exhaust system with X pipe, Ported TB, VARARAM, and a 180 Deg T stat on my 02 ZO6 and didn't tune it for 6 months. In that 6 month period, here is what I learned:
- Exhaust STINKS because it is WAY rich!!
- Lots of carbon/exhaust suet on the exhaust pipe outlets
- Fuel Mileage went from 29-30 highway to 23-24 highway.
- Throttle Flat Spot transiting from 1800 RPMs to 2500 RPMs
- Power Gain was good!!
- No DTCs, engine issues or damage noted.
After the tune:
- No more exhaust stink issues!
- Fuel Mileage increased
- MORE POWER! EXCELLENT!
- MUCH IMPROVED throttle response!
- Clean exhaust pipes and improved exhaust note!
You will be MUCH happier if you limit the period of time between install and tune but it shouldnt hurt anything IF everything works corectly.
BC
BC
Old May 30, 2011 | 11:08 AM
Randy_medion's Avatar
Randy_medion
After the tune:
BC
BC
how about only LT headers will that drop my highway MPG too???
