•• FAST 102 Intakes (LS1,LS3,LS7,Truck) ••
Old 03-18-2010, 12:30 PM
0HinsonSuperCars
Former Vendor
HinsonSuperCars's Avatar
Location: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Originally Posted by allngn_c5
Hopefully you have the oppurtunity. Thanks for the response.
I may be posting up some solid a-b comparison information in the next few weeks. It all depends on if I have a buyer and can get away from work.
Sounds good.
Seth
Old 04-07-2010, 01:37 PM
Corvette Don
Corvette Don's Avatar
I will wait for the results between the 92mm and this one. I dont need to buy one for a few months anyway.
Old 04-08-2010, 04:29 PM
0HinsonSuperCars
Former Vendor
We haven't done any before/after dyno testing on the 92 vs. 102, but there's some results over on LS1tech showing gains of 9 rwhp.
Seth
Old 04-30-2010, 05:08 PM
Corvette Don
So is the actual intake itself the SAME on the inside as the 92mm? Or is it a completely different intake?
Old 05-04-2010, 05:24 PM
0HinsonSuperCars
Former Vendor
They're different on the inside. The 102 has individual removable runners.
Seth
Old 05-10-2010, 03:04 PM
Blue Angel
Blue Angel's Avatar
Seth
Is that the only change? The runners are removeable?
Has anything changed with the shape/length/profile/volume of the runners? Is anything FUNCTIONALLY different between the 92mm intake and the 102mm intake other than accomodating a larger throttle body?
9rwhp gains... on what combination? How much power was it making before the swap?
Expand please!
Old 05-11-2010, 05:45 PM
0HinsonSuperCars
Former Vendor
Expand please!
The construction of the intake and runners is different from the 92, along with the obvious 102mm opening. The 102 is making a few more horses over the 92 from the design changes. As far as the exact measurement differences of everything, I don't have that info. There's more information on LS1tech from the back to back testing that was done.
Seth
Old 06-04-2010, 11:34 AM
LightFighter_GXP
LightFighter_GXP's Avatar
doesn't fast have a billet fuel rail kit that comes with the hoses for around $225?
Old 06-04-2010, 06:04 PM
0HinsonSuperCars
Former Vendor
The FAST Billet Fuel Rails LS1/LS6 are $189.99. The FAST Crossover Line is $44.99. The FAST Crossover Line is just the front crossover line & fittings that connect the Fuel Rails to each other and does not include the rear line & fittings that you'll need to connect the Fuel Rail to the OEM fuel line.
Torrent carries the Billet Fuel Rails and complete Fuel Line Kits in multiple colors http://forums.corvetteforum.com/c5-t...uel-lines.html
Torrent Rails and Lines pictured
Seth
Old 06-04-2010, 09:02 PM
LightFighter_GXP
thanks for the info..... I got a set of those.. and there nice!!!!
Old 06-07-2010, 01:07 PM
0HinsonSuperCars
Former Vendor
Old 06-15-2010, 11:16 PM
Oh4GTO
Oh4GTO's Avatar
What gains have you personally seen with the FAST over stock LS3 manifold?
Old 06-17-2010, 02:03 PM
  #33
0HinsonSuperCars
Former Vendor
On the LS3 version, our test results showed low gains (under 5 hp).
Seth
Old 06-24-2010, 04:26 PM
  #34
vette1017
vette1017's Avatar
It should be noted that the FAST 102 is not a direct bolt on replacement for a LS1 intake. To my surprise, considerable extra work is required. If I had known that I might have went with the FAST 92 .
Old 06-25-2010, 04:34 PM
  #35
0HinsonSuperCars
Former Vendor
On the last C5 in our shop all we did was trim the outer shell on the Intake to make it so it wouldn't hit the cowl.
Seth
Old 07-21-2010, 05:37 PM
  #36
Umrswimr
Umrswimr's Avatar
Location: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
They're the same material. We are using the FAST 92 on our 8 second twin turbo LS1 RX7. We were running 24 psi last time out. No problems.
Seth
I did not realize you could put the intake manifold on backwards...
Old 07-22-2010, 04:13 PM
  #37
0HinsonSuperCars
Former Vendor
To •• FAST 102 Intakes (LS1,LS3,LS7,Truck) ••
Old 08-24-2010, 01:27 PM
  #38
0HinsonSuperCars
Former Vendor
Thanks for your orders!
Old 08-24-2010, 07:27 PM
  #39
LightFighter_GXP
if I get the Truck intake what kind of rails do I need for an 02 5.3L?
Old 08-25-2010, 01:41 AM
  #40
LightFighter_GXP
since the heads go on either side of the motor... the intake can go on either way... and the headers can go on upside down!!! the intake is on reversed from the factory on an LS4 FWD V8 cars
Quick Reply: •• FAST 102 Intakes (LS1,LS3,LS7,Truck) ••
