i have a 1989 c5 and i need a new fuel pump and sending unit. i have seen several different brands and also one that mounts out side of tank. my sending unit is also bad and i will replace at same time. i was going to get a/c delco but saw different brands. any suggestions
Assuming it is either a 98 or 99, there are a couple different directions yo can go.
If you're not going to go FI or N2O, and since you say you need BOTH the pump and sending unit, you can probably find someone on here selling the complete set up that will work for you.
If you were just swapping pumps, I would personally go with the LP pump.
