Alright, so I'm driving to a friends house and the car just dies, so i pull over to the side of the road and try to start it and it would only stay on for about a second or 2 then shut off, then i check under the hood and everything looks ok, so then i try to start it again and it just starts cranking over but wont turn on. i then try to hear if my fuel pump comes on but i don't hear anything, i also check my fuel pressure gauge and there is no fuel pressure. could this by any chance be a bad fuse or relay, or did the fuel pump go out. BTW its a 03 z06 and i believe the fuel pump is on top of the gas tank, it also has a kenne bell boost a pump and a racetronix harness.
Depends what date your car was built, as to whether it has FFS or not. Really easy to determine by looking at the tank though. Do you have access to a DMM? Have you checked the fuel pump fuse?
Check the fuses 1st... Then check the wiring harness for your racetronix. It may have gotten jarred and gotten too close to a hot pipe. I lost my Fuel pressure once when the hot wire for the fuel pump got too close to the manifold. Fuse looked great.. but no pressure..LOL
CONTACT RACETRONIX SUPPORT!!!
We can get you all the proper diagnostic info and tech help you need.
Alright everyone, i had checked all the factory fuses yesterday before i had to call a tow truck and everything looked great. today i checked a couple of other things and i found that the fuse for the racetronix harness blew out. i replaced it and the car started right up. i really don't know why that happened, but I'm thinking it might of had something to do with a bad ground i had a couple of days ago. thanks everyone for there advice.
