Turning the engine over by hand
Old Mar 1, 2010 | 04:38 PM
chevylad's Avatar
chevylad
Default Turning the engine over by hand
Anybody got a good way to turn the engine over by hand with the steering rack in place from on top so I can see a dial indicator on a valve. I can do it from underneath, but then I need two people. I was thinking of making something, but it's a pretty tight fit. I do have an ARP balancer bolt so it's a twelve point.
Old Mar 1, 2010 | 04:57 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I made a tool by shortening a socket about 1/2", and welding it to a pc of flat stock....looks like this:
This will work on a stock or Powerbond balancer, where the front of the pulley is mostly open, and there is room to slip the socket in between it, and the rack.
But on a closed-face balancer (such as the ATI), there's just no room to get anything on the bolt head with the rack in the way. In that case, you can use a non-metallic strap wrench wrapped around the balancer to turn it over.
Old Mar 1, 2010 | 05:08 PM
vettenuts's Avatar
vettenuts
I made something similar for the stock setup and have one that works for the ATI I have installed. Its ugly but works well.
Old Mar 1, 2010 | 05:48 PM
chevylad's Avatar
chevylad
I like that tool. It doubles up as an attitude adjuster as well.
Old Mar 1, 2010 | 05:56 PM
jedblanks's Avatar
jedblanks
Remove the spark plugs and belts, then use strapwrench or even hands?
Should turn over easily once you remove the compression.
Old Mar 2, 2010 | 12:22 PM
SDPC's Avatar
0SDPC
Former Vendor
I just use a box end wrench on the ARP bolt, it sticks out far enough to do it without a problem
Old Mar 2, 2010 | 12:28 PM
chevylad's Avatar
chevylad
what brand wrench? Doesn't it have to sit in kind of deep?
Old Mar 2, 2010 | 12:38 PM
SDPC's Avatar
0SDPC
Former Vendor
I have snap-on and proto and both work fine. The box end is at an angle and it's enough to get on there great
Old Apr 14, 2010 | 10:22 PM
chiefsr's Avatar
chiefsr
What's an ARP bolt?
Old Apr 15, 2010 | 05:43 AM
vettenuts's Avatar
vettenuts
Originally Posted by chiefsr
What's an ARP bolt?
Automotive Racing Products (ARP) makes aftermarket fasteners and in particular they make a reusable bolt for the harmonic damper (pulley) on the LS1 motor.
To Turning the engine over by hand
