Quote:
Originally Posted by plunkman
Fellow C-5 owners I have a 2000 coupe 6sp. transmission with a callaway cold air induction as the only after market device. I am interested in changing the stock mufflers and pipe from the cat back. What is the best performing brand and how much of a gain in horsepower/torque can I realistically expect?? also who is the best/less expensive dealer to buy from. ? thanks jp.
Below are a couple dynos showing 10-12 rwhp gains with catback only before after results with catback only. Also in my research I have seen some members on this board with C5 manuals with catback only dyno higher vs stock exhaust manual. IMO from research there seems to be a pick up of rwhp with a catback only system imo anywhere from 8-12rwhp depending on the system.
C5 auto dyno gain with catback only
13rwhp
DYNO TEST RESULTS
STOCK BASELINE B&B BULLET CAT-BACK B&B BULLET W/ HEADERS
RPM RWHP TORQUE (lb-ft) RWHP TORQUE (lb-ft) RWHP TORQUE (lb-ft)
2000 105.8 277.7---- 108.6 285.3---- 111.2 292.0
2200 117.6 280.6---- 120.5 287.8---- 123.4 294.7
2400 130.0 284.5---- 133.2 291.4---- 136.4 298.6
2600 142.5 287.9---- 146.0 295.0---- 149.5 301.9
2800 154.6 290.1---- 157.2 294.9---- 162.1 304.1
3000 166.2 290.9----169.9 297.4---- 174.2 305.0
3200 178.6 293.1---- 182.5 299.5---- 186.8 306.5
3400 190.9 294.8---- 195.3 301.7---- 199.2 307.6
3600 203.6 297.0---- 208.5 304.2---- 212.3 309.7
3800 216.5 299.2---- 222.5 307.5---- 227.0 313.7
4000 229.5 301.3---- 236.0 309.9---- 241.0 316.5
4200 239.9 299.9---- 248.0 310.1---- 253.6 317.1
4400 249.6 297.9---- 258.0 308.0---- 265.1 316.4
4600 260.3 297.2---- 270.0 308.2---- 277.1 316.4
4800 271.3 296.9---- 279.7 306.1---- 287.1 314.1
5000 280.4 294.6---- 289.9 304.6---- 296.7 311.7
5200 286.1 289.0---- 297.6 300.6---- 303.2 306.2
5400 290.1 282.2---- 299.9 291.7---- 306.9 298.5
5600 289.4 271.4---- 300.8 282.1---- 308.0 288.1
5800 290.4 262.9---- 301.6 272.3---- 305.3 276.4
6000 285.8 250.2---- 296.4 259.4---- 305.0 267.0
6200 282.0 238.9---- 293.8 248.9---- 299.8 253.9
PEAK STOCK 286.1 hp @ 5200 rpm
301.3 lb-ft @ 4000 rpm
BULLET CAT-BACK 300.8 hp @ 5600 rpm
310.4 lb-ft @ 4100 rpm
BULLET W/ HEADERS 308 hp @ 5600 rpm
317.1 lb-ft @ 4100 rpm
http://www.vetteweb.com/tech/0501vet...ust/index.html
12rwhp
BASELINE MagnaFlow w/mufflers mufflers and & x pipe
RPM HP TORQUE (lb-ft.) HP TORQUE HP TORQUE
--------Stock--------Magna Muff----Muff w/X
3,900 206.5 278.1-- 220.8 297.4-- 222.1 299.1
4,000 219.9 288.8-- 226.2 298.1 --227.7 299.7
4,100 225.1 288.3-- 233.2 298.7 --234.6 300.6
4,200 231.7 289.8-- 239.8 299.8 --241.2 301.6
4,300 235.8 288.0-- 244.3 298.4 --246.1 301.1
4,400 242.3 289.2-- 249.5 298.1 --250.9 300.7
4,500 246.5 287.7-- 255.6 297.8 --257.6 300.6
4,600 246.9 286.4-- 260.5 297.4 --263.0 300.3
4,700 248.3 282.1 --265.6 296.9 --267.6 299.9
4,800 249.9 279.2-- 270.9 296.4 --274.1 299.0
4,900 251.6 266.6-- 276.0 295.8 --278.2 298.2
5,000 258.4 274.5 --278.4 292.5 --283.6 298.0
5,100 264.2 272.1-- 277.7 290.9 --285.7 294.2
5,200 269.3 272.0-- 288.0 287.1-- 290.6 293.6
5,300 271.4 268.9 --289.7 286.0 --290.7 288.1
5,400 273.5 266.0 --290.1 281.2 --291.6 283.6
5,500 274.9 262.6 --291.6 278.5 --293.9 280.7
5,600 275.6 258.4 --292.6 274.4 --294.0 275.7
5,700 277.8 256.0-- 293.4 270.3 --294.4 271.3
5,900 279.8 249.1-- 292.8 260.7 --295.1 262.7
6,000 278.6 243.9 --290.9 254.6 --293.4 256.9
MAX HP
[email protected],900 rpm
MAX TORQUE (lb-ft.)
[email protected],200 rpm
[email protected],800 rpm
(+13.9 over base)
(+10.0 over base)
295.6 @5,800 rpm
(+15.8 over base)
(+11.8 over base)
http://www.exoticperformanceplus.com....html?item=461
