what to replace on ls1 motor with 140k on clock?
hey guys i have an oil leak somewhere on my car. i just replaced the intake manifold gaskets when i was replacing an OPSU (which has already went out with less than 3k miles). Everytime i get out of car i can smell burnt oil. i have a friend who has a shop to do all the work on car. he is very knowledgeable about ls1's... so what else should i replace? timing chain, valve cover gaskets, oil pump... what else? and how much do you think parts would be for these items and others that i should include. right now the car has a stutter while in gear at idle.
My car is a 98 c5 a4 with 140k on the clock. thank you for the input i need this car to keep going since it is my DD. only things on car is flowmaster over axle exhaust with x pipe, blackwing intake, and a rebuilt trans with shift kit...if that matters. i want to do a mail order tune after i finish the TLC on the motor that way my basic mods are tuned to car.
thank you for input
cody
thank you for input
cody
Received 1,194 Likes
St. Jude Donor '15
these engines are good for a lot more than 140k miles. fix the leak and leave it alone, imo.
St. Jude Donor '15
i mean, it's not going to hurt anything to do it..and if you're already going to have it apart then sure.. but i wouldn't tear into a perfectly good engine to change that out if you have good oil pressure already
St. Jude Donor '15
i doubt it.. no way you're leaking enough oil to affect pressure.. unless you're putting in a quart every 10 miles or something.
ya i check my oil regularly and it has never been low but i can just smell it EVERY time i get out of my car. i change my oil every 3k miles with mobile 1 synthetic
Do you park your car in the same spot every night? If you have an oil leak on the backside of the engine (OPSU, valve cover gasket, rear main), the oil might fall onto the exhaust and create the odor you've described. If you park in the same spot, are there any traces of oil on the ground?
im not sure on the parking spot as i have just moved but i will start looking everyday. yes i can smell it getting out of the car and even sometimes when idles at a stoplight for example
Even at cost....it doesn't make any sense. You are changing synthetic oil...at the same interval as organic oil. It's not only a waste of money.....it's a waste of good oil. Even if you were getting the oil for free........it's just pointless.
i live in ca temps rise to 120 degrees F... my car is a DD so i make sure i have fresh oil at all the times. i would rather spend the 30 bucks every few months then have to replace things prematurely
