Comp Rocker Arm Trunion Upgrade - $199 shipped with labor
#41
Simply send us your factory rockers and $199 and enjoy reliable operation for years to come. $199 includes the Comp Rocker Arm Trunion Upgrade Kit, installation labor, and shipping back to you.
This is a very wise investment in your stock LS1/LS2 rocker arms. High rpm and high valve spring pressures can put the factory rocker arm’s trunion under intolerable stress. The factory needle bearings are replaced with caged roller bearings to increase rigidity & reliability. This will keep needle bearings from falling out everywhere in your engine. As proof of success, for the last two years this rocker arm trunion upgrade has been tested and performance-proven in the NASCAR GM LS spec engine series. This performance rocker arm modification is a “must have” upgrade for your LS1/LS2 factory rocker arms.
1. Mark each rocker arm (1-16) with a sharpie. This will insure the wear pattern will remain the same as before and that there will be no excessive noise after installation.
2. Send your rockers to the following address:
Hinson Motorsports
1500 Hueytown Rd.
Hueytown, AL 35023
3. Turnaround time is 1 business day. Express shipping is available if needed.
Parts
Installed
Hinson Motorsports
1500 Hueytown Rd.
Hueytown, AL 35023
Parts
Installed
