Proper Tire Pressure?
Thank you for your thoughts
Bill aka ET
I speak for many many Vette owners here on this forum when I say that I trust Evil Twin in everything he says about the C5 Corvette...well maybe not everything...he may make one mistake in 10,000 posts
3 cheers for Evil-Twin...one of the CorvetteForum's greatest assets.
Flame suit on just incase...
ET has been a member of CF way before I was ever a member. He has been a KNOWN respectable contributor of FACTUAL KNOWLEDGE "FOREVER". Hell,,, he helped build the car your driving!Being that I have reviewed and followed his advice and proven that its correct,,,,,,,,I can HIGHLY recommend you follow his advice. Plain and simple,,,,,,,,,,,he's correct with tire pressure recommendations.
I keep my tire pressure at 28 psi rear cold and 30 psi front cold and have EXCELLENT wear characterics. The way I drive and the way my tires wear ,,it works,,those pressures work excellent for me.
ET's guide lines will give you excellent over all results. If you start to see abnormal wear,,,you will have to correct mechanical issues or alter the pressures "SLIGHTLY" to compensate for how you drive and if you run different tire sises than OEM.
I stager front to rear pressures because I run wider than stock rear tires. I have 315 TOYO proxis T1Rs on CCW 505a's vs the stock size on the stock rim.
BC
BC
Another ET follower/believer...
...and BTW Bill #2, I will be taking your advice you emailed to me a while back about the Toyos
Did I already mention this?>>>
HAPPY BIRTHDAY ET
