It's been a while, and I don't want to start opening the bottom.
Is it possible to change the bulb from the top by removing the healight sides and top? Thanks!
You don't have to remove headlights to get to the bulbs. You just need someone with small hands to reach in and pull them out. My wife changed out mine.
Manually opening the headlight,removing the bezel,and removing the hood support (long stud with the rubber bumper on top) makes it a lot easier to get your arm in there.
Put a mark on it so you know how far to screw it back in to keep the hood flush with the front fascia.
Thanks everyone, I did get to it from the top by removing the headlamp side and top cover. It worked out real well, and I found the infamous crack over the bulb area. I fixed it with silicon sealer. Probably will have to check the other side now.
