fabricated alluminum valve covers
04-29-2010, 03:46 PM
2nd Gear
Has anyone installed a set of these on a c5.
I seam to have alternator clearence problems
04-29-2010, 05:01 PM
Yes I have these valve covers and you have to cut out a section for the alternator because the covers are to tall. Crappy thing is that I had mine adjusted and now I want to go a different route so they are probabbly going to go back on the auction site.
04-29-2010, 05:06 PM
I didn't want to cut/grind them up, so I just resold them to a guy that didn't mind. Bad engineering, if you ask me.
05-09-2010, 03:20 PM
2nd Gear
Thanks. I spoke to my local Vette shop and they said you could use an alternator relocator brack but I am having trouble finding one...any input?
05-09-2010, 07:15 PM
relocate the coils and be done with it..
05-09-2010, 07:58 PM
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Quote:
Originally Posted by
joshtownsend
How does that prevent a tall valvecover from not hitting the alternator?
05-09-2010, 08:10 PM
I took a grinder to my alternator bracket, bolted them on, then the fuel and return line were in a bind. they are a bad design.
05-09-2010, 09:11 PM
St. Jude Donor '10
joshtownsend
got any pics?
05-09-2010, 10:23 PM
David Q
I agree that it is a bad design. I went with Katech cast aluminum and had no clearance issues..
05-10-2010, 12:51 AM
I had the same problem because of my taller heads. I made 2 little extension brackets and bought a 1/2" longer belt.
