Valve Cover Breather Solution Needed
Old May 3, 2010 | 09:37 AM
FRC Joe's Avatar
FRC Joe
Default Valve Cover Breather Solution Needed
I need to come up with a different solution for my valve cover breather. I'm running the GMPP "Chevrolet" valve covers, which have a plain 1.22" dia hole on the pax. side cover. I'm currently using a K&N breather filter that I've modified the base of mounted directly in the hole. It's just a standard K&N part that has no baffles etc. and the problem seems to be that since the breather is mounted at an angle, oil mist trapped by the filter element is dripping out of the low side of the breather. Here's a pic of the arrangement, you can see where the oil has been.
What I'm looking for is either an attractive looking push-in style cap with built baffles and breather, or an elegant solution to go from a plain 1.22" hole to AN-6 hose and then to a remote breather can. I have 1.00" and .75" grommets for the valve cover hole.
I was thinking maybe a 1/2" NPT to AN-6 elbow, screwed into the .75" grommet. The O.D. of 1/2" NPT is .840", so it'd be a tight fit for sure. Anyone have a line on a better solution? Maybe a 1.00" or .75" hose barb to AN-6 adapter elbow? Any other suggestions are appreciated!
Old May 3, 2010 | 09:48 AM
lucky131969's Avatar
lucky131969
I would not refer to my solution as "elegant", but it works very well.
Old May 3, 2010 | 10:17 AM
hotwheels57's Avatar
hotwheels57
Have a machine shop make a billet aluminum cap for the GMPP valve covers. They might even be available in the after market. If any place would, it's STREET & PERFORMANCE...
http://www.hotrodlane.cc/
It shouldn't be that expensive to make one up whether it's push in or threaded. Have them machine the cap to accept an AN fitting in whatever size you want.
Old May 3, 2010 | 10:46 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Also not a very "elegant" solution, but a 70's GM type (AC Delco FB-59 or equivalent) PCV breather filter will push right into the valve cover grommet.
Position it with the open side of the filter element facing toward the upward side,
and any oil residue will then drain back into the valve cover.
Old May 3, 2010 | 01:39 PM
FRC Joe's Avatar
FRC Joe
Good info guys, thanks! I think I'll pick up one of the FB-59 type filters tonight and use it in the short term, while looking a little deeper at the solution lucky131969 uses. If I do go a custom fab route I'll probably have one of the male AN-6 weld fittings I've got laying around welded directly to the top of the VC, althoug a custom cap with welded or screwed in fitting like hotwheels57 suggests could look cool as well.
To Valve Cover Breather Solution Needed
