Air Conditioning Problems....A/C light wont stay on
#44
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My buddy had the same issue with his 2000 coupe. The headers burnt the line. He had an AC Shop make a custom line that no longer contacted the headers.
PROBLEM SOLVED
PROBLEM SOLVED
#46
CI 6,7,8,9,11 Vet
St. Jude Donor '08
A leak is a leak. If you hire a LAZY AC mechanic, he may not go the extra mile to find that leak. When the dye leaks out, it leaves a visible stain. If that stain is inside the Air Box, no one is going to see it. Using a long wand sniffer, you can detect that leak.
You have AC hose joints
on the fire wall. Some are difficult to see. A good flashlight and a mirror will allow you to find the joints and the black light will show the leak.
You need to find a good competent AC Shop that knows what they are doing.
Armed with a GOOD Halon detector and dye and a black light, you SHOULD be able to find ANY LEAK.
Bill
Bill
