Car wont start... Please need help
Jul 31, 2010 | 10:08 AM
Hi,
My 01 has been on a charger, lights and all items are working. When I turn the key I get nothing. Its as if you tried to start it without pushing in the clutch. No noise or anything.
Any ideas.
Thanks,
Bobby A
Jul 31, 2010 | 10:30 AM
Well here is what happened, I pushed down down on the clutch several times in a row and it started. ????
What do you think occured and should I now be worried that it may happen again?
Has this happened to anyone?
Thanks for looking,
Bobby A
Jul 31, 2010 | 10:36 AM
The security light came on as it normally does. Goes off when key is turned.
Everything was just as it normally is.
I wonder if it is something with the depression of the cluthch. There must be a switch that allows the car to start when the clutch is depressed.
Is that something that I can eyeball or easily check?
Thanks again,
Bobby A
Aug 4, 2010 | 06:10 PM
Thanks,
I am going to check out the switch this weekend. Ill post what I find.
Bobby A
Aug 4, 2010 | 09:53 PM
St. Jude Donor '08
Quote:
Originally Posted by
Bobby A
Thanks,
Bobby A
It's a $15 or so switch and it has no adjustment. It simply slides into place and locks in on two sliding tabs.
There should be a connector going into it with Yellow and Purple wires.
