what wire is this?
Old Sep 8, 2010 | 07:00 PM
spoolin7's Avatar
spoolin7
Default what wire is this?
i don't have a wiring schematic for the car yet. i need to know what the grey wire on the connector just to the right of the trans (Letter G on the connector) is. i'm 99% sure it's for the fuel pump, but would like someone to verify.
Old Sep 8, 2010 | 07:05 PM
lucky131969's Avatar
lucky131969
Oh yeah, the grey wire on the connector to the right of the trans..
How about a pic....or a tad bit more detail..
Old Sep 8, 2010 | 07:21 PM
spoolin7's Avatar
spoolin7
if i showed you a picture would you know what it is?
the car isn't here at the moment so i can't snap a pic. it's just to the right of the area where the trans and diff meet. it has 10 pins, but i believe it only has 9 wires. 2 of them, black and grey, are larger than the rest.
Old Sep 8, 2010 | 07:23 PM
lucky131969
Probably not......I'm not very good with electrical stuff . Just thought it might help out some of the more experienced guys on the forum.
Old Sep 8, 2010 | 11:04 PM
byronhunter's Avatar
byronhunter
Is this it? You do know Lucky is Joking don't you? He's good at electrical stuff.
Connector Part Information
12045809
10-Way F Metri-Pack 150 Series (BLK)
12045808
10-Way M Metri-Pack 150 Series (BLK)
Pin
Wire Color
Circuit No.
Function
Pin
Wire Color
Circuit No.
Function
A
PNK
339
Battery Positive Feed
A
PNK
339
B
WHT
1310
Evaporative Emission Vent Valve Solenoid
B
WHT
1310
C
GRY
720
Fuel Level Sensor Ground
C
GRY
720
D
DK GRN
890
Fuel Tank Pressure Signal
D
DK GRN
890
E
GRY
598
5 Volt Reference
E
GRY
598
5 Volt Reference
F
BLK
150
Ground
F
BLK
150
Ground
G
GRY
120
G
GRY
120
H
DK BLU
1936
Fuel Level Sensor Signal-Left
H
DK BLU
1936
J
LT BLU
1937
Fuel Level Sensor Signal-Right
J
LT BLU
1937
K
Not Used
K
Not Used
Old Sep 9, 2010 | 09:33 PM
spoolin7's Avatar
spoolin7
that would be it. i appreciate it! i assume it means it's the feed to the pump. that's what i was figuring, but had to double check
To what wire is this?
