Turn signals not working
I replaced my switch by just removing the knee bolster and there is a hole or access under the dash beside ignition switch that U can get your hand up under dash and wiggle the swithch out after you get it loose from the front. Remove the haz button, use a small screw driver to push and pry from the bottom of switch until it is loose and then take big screw driver and whack or bump the top of the switch. This will release the switch and you can reach up under dash through this hole I described and wiggle the switch out. I just unplugged old switch and installed a new one and just left it under the carpet beside the console for easy access next time and put the haz button back into the original switch hole for looks only. I had to wrap several raps of tape around it to get it to stay in the hole. about a 30 minute job, there is a You tube of a guy doing it this way.
JBB (07-21-2018)
I am having the same issues with the signals not working. I have a hyper flash harness already installed with switchback LEDs
The first thing I did was clean the contacts on the bulbs and the sockets used dielectric grease and reinstalled. Worked for a couple of days and came back.
I have been reading up and it appears that the hyper flash would fix the issue but not so for me.
I have ordered a new hazard switch and harness. I will try that first and leave the switch in an inconspicuous spot to see if that cures the problem. However I am thinking the problem could be the drl sockets. So that will be step 2.
Inspection is due in June so i really need to get this sorted.
mike v
Here is some info that might help. (do a search above)
How to fix your hazard flasher/turn signal problem.... and there is also other info..
mike v
mike v
2006 C6 right turn signal
I have 2006 Corvette C6 for the last two years my turn signals on the right side only works 75% of the time I have changed all bulbs and also check ground wires replaced the turn signal switch I am out of ideas please help
