Replacing knock senesors in a '97
Should I go with a knock sensor for a newer model? I see different part numbers listed for different years. I am getting some ping from time to time and my tuner wants me to replace the knock sensors 1st. He says the '97 knock sensors "suck".
So your tuner thinks the knock sensors are causing the pinging/spark knock?
Yeah, that's what I'm thinking too.
I looked a little closer at he knock sensor part numbers. Looks like they are the same from 99-04 with '98 having "1st design with locating tab" and "2nd design W/O locating tab".
I guess my question is; Is one more sensitive than the other?
If you have spark knock(profound enough to be picked up by the sensors), and the PCM is not pulling timing, then you may have a sensor/harness issue(which should generate a code), or the sensitivity is turned down.
