what's wrong with my lights ?
Old Oct 8, 2010 | 12:29 PM
eldudereno's Avatar
eldudereno
Default what's wrong with my lights ?
Am running with HID fogs and HID ACA headlights and no problems at all until now.
First click on the stalk brings on the fogs just like usual but my pop-ups are now popping up at the same time but the lights aren't coming on. Second click on the stalk now brings on my driving lights. When I go back one click to the fogs the driving lights go off but the pop-ups stay up (common problem with HID's). When I now switch my fogs off (all lights off) the pop ups now go down but the motor/gear still turns on the left hand side pop-up for about 4 seconds.
I know that the teeth on the gear wheels can shear off but is this problem consistant with that?
any advice would be very much appreciated
thanks
Old Oct 8, 2010 | 01:01 PM
robert21122's Avatar
robert21122
do you have capacitors on your hids
Old Oct 8, 2010 | 01:04 PM
lucky131969's Avatar
lucky131969
You mean "resistor"...right?
Old Oct 8, 2010 | 01:23 PM
SaberD's Avatar
SaberD
this is how the stock headlights are supposed to work. no problem here.
if the motor still spins after the lid is down, you have stripped headlight gears.
Old Oct 8, 2010 | 01:26 PM
robert21122
yeah my bad they both store power. you only need them for your low beams
Old Oct 8, 2010 | 02:02 PM
lucky131969
No, they both do not store power. Capacitors hold a charge, resistors do not.
Old Oct 8, 2010 | 02:14 PM
robert21122
o so why is it when the car is off i turn lights on for like five mins turn off they dont go down
Old Oct 8, 2010 | 02:20 PM
lucky131969
Good question, start a thread, and ask for help with details on your particular situation. I'm just clearing up your misunderstanding of capacitors v/s resistors.........so you don't confuse others.
Old Oct 8, 2010 | 03:26 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Replace with brass units
http://forums.corvetteforum.com/c5-g...orialized.html
Old Oct 8, 2010 | 05:47 PM
eldudereno's Avatar
eldudereno
Many thanks for the replies.
A stripped gear it is then but why are the lights popping up when they've never done this before? I haven't got the resistor.
Old Oct 8, 2010 | 06:00 PM
JW Motorsports
Banned Scam/Spammer
thanks
I'm not sure why it does that really. For some reason a lot of C5s do that when you change to HID fogs. It's one of the only drawbacks to having the nice light.
Change the gear out first though. Some do that when the gear is bad.
Old Oct 8, 2010 | 07:37 PM
robert21122
when i turn my fogs on my lights come up to but they go down if you turn them back off to just fogs but get some resistors
Old Oct 9, 2010 | 04:09 PM
eldudereno's Avatar
eldudereno
Thanks, will turn the gear around 180 degrees for a quick fix but will also order the brass upgrade.
Yes, will buy the resistor as it's a little embarrassing when you can only drop the pop-ups by switching all of the lights off.
To what's wrong with my lights ?
