Headlights don't turn on unless engine is off
Old Oct 30, 2010 | 06:49 PM
VetteDawg's Avatar
VetteDawg
Default Headlights don't turn on unless engine is off
A little strange, no?
If I take off and then decide that I should have my headlights on...they won't come on. I have to stop, shut the car off and THEN turn the headlights on. They will now come up and I can start the car and drive.
If I turn them off while the car is running they won't come back on (on occasion they will but most times they won't).
Any ideas?
Old Oct 30, 2010 | 08:15 PM
PEERPSI's Avatar
PEERPSI
Do the lights turn on and the door does not go up or neither come on?
Old Oct 30, 2010 | 09:09 PM
VetteDawg's Avatar
VetteDawg
I don't think that the lights come on until I get them to pop up.
Old Oct 30, 2010 | 09:21 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Sounds like the usual headlamp/multifunction switch.
PEERPSI's Avatar
PEERPSI
Do you have the automatic headlight option? Is it turned on? If so the interior fuse panel has a relay number 44 that operates the headlights. Locating this can be accomplished by finding the fuse panel information in your owners manual.
Old Nov 2, 2010 | 10:28 PM
VetteDawg's Avatar
VetteDawg
No, do not have automatic headlights.
What is the headlamp multifunction switch? Is that the switch arm on the steering wheel column?
Old Nov 3, 2010 | 06:12 AM
PEERPSI's Avatar
PEERPSI
Yes.
Old Nov 3, 2010 | 09:11 AM
dgrant3830's Avatar
dgrant3830
There are only a couple of components in the system. The headlamp/multifunction switch on the column, the headlamp controller on the right forward frame rail directly behind the right headlamp and lastly, the BCM itself which sees the light sensor, headlamp switch and the programming of the twighlight system.
Old Nov 3, 2010 | 01:36 PM
PEERPSI's Avatar
PEERPSI
Also relays, OP says he doesn't have the twilight system.
Old Nov 3, 2010 | 11:21 PM
VetteDawg's Avatar
VetteDawg
....but why on earth would the lights come up EVERY TIME if the car is NOT running....but only come up once in a blue moon when the car IS running? I mean, that's bizarre.
Old Nov 18, 2025 | 08:36 PM
C5drifter's Avatar
C5drifter
I have the exact same issue now, does anybody know what can cause this?
Old Nov 19, 2025 | 10:24 AM
lucky131969's Avatar
lucky131969
Best to troubleshoot using the schematics when you have a hard fail.
Old Nov 19, 2025 | 05:23 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Call me crazy, but I always assumed that the headlight motors weren't strong enough to overcome airflow over the car, when the car is moving, therefore they only open when the car is stationary. Therefore, OP, when you say "the car is running", do you mean the engine is running but the car is stopped, or the car is in motion?
Old Nov 19, 2025 | 05:43 PM
lucky131969
Good one....
Old Nov 19, 2025 | 06:12 PM
C5drifter's Avatar
C5drifter
Even when the car is stationary they still don't pop up unless the ignition is off. Doesn't make sense why they wouldn't pop up while the car is running and work perfectly fine when the car is off, I'm going try turning the twilight setting off to see if that is somehow making it play up.
Old Nov 20, 2025 | 10:07 AM
vito02's Avatar
vito02
Any ideas?
Looking quickly at the schematic, in order for the headlamps to come on the Body Control Module must ground the coil of the headlamp relay. Although I agree that diagnosing the circuit with a voltmeter when the symptom is present is the better approach, I would try checking, then removing all fuses that supply the BCM and waiting 15 minutes before reinstalling them.
Please disregard the foregoing as it pertains to the Body Control Module and the Headlamp Relay. Lucky131969 kindly provided a better schematic than the one I referred to. The headlamps should work regardless of the contact status of Relay 44.
Old Nov 20, 2025 | 11:19 AM
lucky131969
That is only if you have the twilight sentinel option, and of course....it is enabled.
...relay 44 has nothing to do with manually turning on the headlights via the MFS.
....and what does this accomplish? Troubleshooting in a hard fail state is the best way.
Old Nov 21, 2025 | 08:48 AM
vito02's Avatar
vito02
Thank you. The schematic you provide shows clearly that the MFS should receive constant B+ power from the circuit breaker in Position 54 - IP Fuse box. So the headlamps should work regardless of the contact status of Relay 44. Please see my edited post.
Old Nov 21, 2025 | 02:49 PM
TonyCorvette_'s Avatar
TonyCorvette_
It’s a funny circuit. The open and close signals are on different supplies so it’s possible to have both open and close commands simultaneously if the MFS is sticking. Can have it tested on eBay.
To Headlights don't turn on unless engine is off
