LSX iron block for boost 9:1 comp.Jegs
Has anyone,,,,or know of anyone,, who used this 9 to1 iron block for boost and how it performed..i am figuring on ordering it in jut a few days....thanks Greg
http://www.jegs.com/i/GM-Performance...ductId=1277010
Former Vendor
1 Post
St. Jude Donor '10-'11-'12
Waste of money at those cubes with that block. I can build you a 434, use much better internals and it will be precision built for boost. $6610 using a Compstar crank or $6385 using a Callies C series crank. Either would be a better build and the money is close.
Does it come with high precision MSD wires and superior quality ARP fasteners?
That is the route I would definately go!
Banned Scam/Spammer
Received 1,319 Likes
FYI -
Within the last two weeks a thread was posted in the FI section where a vendor has claimed issues with 2 different LSx blocks.
One had core shift as delivered, and the block cracked soon after the car went together. For the same customer they got another LSx block from another avenue and had it sonic tested (and failed).
Just letting you know, you may wanna search for that thread and talk to the shop, and then search some more.
ps: what about the blocks blowing as stated in the previous posts
Former Vendor
1 Post
Engine type: LSX Series Gen IV small-block V-8
Displacement (cu in): 376 (6.2L)
Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92 mm)
Block (P/N 19243171): LSX cast-iron with 6-bolt cross-bolted main caps
Crankshaft (P/N 12597569): Nodular iron
Connecting Rods (P/N 12607475): Powdered metal
Pistons (P/N 12166957): Forged aluminum
Camshaft Type (P/N 12603844): Hydraulic roller
Valve Lift (in): 0.551" intake / 0.522" exhaust
Camshaft Duration (@0.050 in): 204° intake / 211° exhaust
Cylinder Heads (P/N 12615879): Aluminum L92 style port; "as cast" with 68cc chambers
Valve Size (in): 2.16 intake / 1.59 exhaust
Compression ratio: 10.7:1
Rocker Arms (P/N 12569167 int): Investment-cast, roll trunnion
Rocker Arms (P/N 10214664 exh): Investment-cast, roll trunnion
Rocker Arm Ratio: 1.7:1
Recommended Fuel: 92 octane
Maximum Recommended RPM: 6600
Reluctor Wheel: 58X
Balanced: Internal
That is what is supplied in your link.
Yes I will supply the same and yes I can deliver a crate style build with intake and oil pan if you like. No, its not shipped at that price.
Warranty ? I guarantee that its built correctly yes for the same 24/50
The difference is I will use a forged crank and rods vs the Nodular iron crank and Powdered metal rods and I'll give you a choice of reluctor wheel vs the 58x only. I'll also grind a custom cam from Comp to meet your needs.
Reluctor Wheel: 58X
Balanced: Internal
Ls2--403 alum. Motor
Reluctor Wheel: 58X
Balanced: Internal
Reluctor Wheel: 58X
Balanced: Internal
it's the LS2 403 alum. for $4895...thanks GREG O.
Former Vendor
1 Post
Thats 100% on the builder. Sometimes parts aren't what they should be, but thats what your paying your builder for. Its their job/responsibility to make sure all the components are proper and put together correctly. Nothing like that should ever slip by or even come close.
Getting freight costs right now, I'll pm you with them.
I don't understand the application that'd be appropriate for that Jegs motor. Undersizing the bore, and using as cast heads with a tiny cam is just wasting a LSX iron block. Why throw away displacement? Not a very good value IMO.
