Who's owned a C5 and an S2000?
PM me if you need any further info; this thread isn't the proper place for continuing this conversation.
which part was better. The fact that is slower in every way or one of the most ridiculous convertible tops put on a car. Maybe one day youll drive a car instead of riding in it.
As far as s2000 vs vette. Corvettes stand no chance in any corner and an s2000 has no chance on any straight away. That being said im selling my s2000 to buy a 03-04 z06.
not me but a friend of mine.
http://www.youtube.com/watch?v=q5Y12ig6v2U
I'll defend that car to the grave. Have you ever actually driven one? If not, then you're obviously ignorant and your opinion doesn't matter. I challenge you to find another car whose transmission, clutch, and shifter works as seamlessly from the factory. And if you can, I suspect it's at least three times the price. Add to that the fact that it has front and rear independent suspension, rear wheel drive, limited slip diff, optional power steering delete, and a good power/weight ratio (only weighs ~2400 lb), and you can't deny that it's a true sports car.
I had a contemporary of it, the Mazda Rx8. I went from a procharged 98 C5 to the rx8(long story). It was fine at first, but after a while I really, REALLY missed the power. I ended up putting a huge turbo on it and made more power than a Z06....but it still felt gutless unless I was running up to the 9500rpm redline. I ended up in another vette. Once you've had the handling balance and torque of a vette.....nothing else will do.
A friend. Of nine has the S2k and. We both agree that my NA Sky is better. Faster handles much better. The redline is even faster. Sorry you are just wrong. Must not have driven a Sky or Sol enough to know. The Sky drives like a slow Vette.
Seriously the Sky/Solstice is an absolute turd. Gotta love the way the top doesn't actually conform to the body.
This makes absolutely no sense. They have a different chassis and one is fwd, the other rwd.
And to the OP your thread is basically screwed. It is now a miata-vs-kappa-vs-s2k thread
If you want a weekend not looking for frills or comfort more hardcore car get a s2k, if you are not a worried about speed and want something cheaper with great handling get a miata. If you want a squishier cruiser get a sky/solstice.
Owned a 2004 S2K for a number of years.
- Yes, there is very little torque, but that is the only real drawback to that car, as I see it;
- The original S2K motor, the F20C, won the International Engine of the Year award in the "1.8 to 2 liter" size category for five years from 2000 through 2004;
- There are few modifications you can perform to an S2K that actually produce more power AND keep Honda's legendary reliability, if any;
- The transmission on these cars is superb, period - it makes the T56 in the Z feel like a turd - while you cannot dispute the strength of the T56, the 6-speed in the S2K is abso-f*cking-lutely phenomenal!;
- The handling is incredible, period. Watch the prototype S2K lap the Nurburgring: http://tinyurl.com/4fz3eo2;
- For those that mentioned not liking the way the car sounded at high-rpm's: Post#6: The sound the engine makes is not particularly appealing and sounds more like your typical run of the mill Civic.
- The only reason I sold the S, was my need for more torque, period. Otherwise, I'd still be driving one.
Last edited by freeman4ever; 01-24-2011 at 05:23 PM. Reason: Deleting one asterisk...I can't spell f*cking correctly! <-- loser
#33
like i said, miata is a thinly disguised 323.
#34
The Mazda B-series engine is a small-sized, iron-block, inline four cylinder with belt-driven SOHC and DOHC valvetrain ranging in displacement from 1.1L to 1.8L. It was used from front-wheel drive economy applications to the turbocharged full-time 4WD 323 GTX and rear-wheel drive Miata as well as numerous other models.
Every car manufacturer with a full line of automobiles uses engine blocks for multiple applications. That doesn't necessarily mean the cars have many similarities beyond this.
#36
For those that mentioned not liking the way the car sounded at high-rpm's: Wow, just...wow. When you hear that motor reving up at 8-9k, it is an aural orgasm. If that high reving NA motor doesn't tickle your naughty spot, better get checked out. No stock civic, Si or otherwise, sounds like an S at/near redline (Integra Type R, maybe); and
#37
Originally Posted by Cybermind
...torque is king. You do agree with me or you would've kept the S2000.......
When I used to roadrace "crotch-rockets," as you call them, I could do 1:03 around our local track on the GSX-R 750 chassis with 1100 motor bored out to 1116 (or near that - it was a long time ago ). I could do the same lap in :57 with a stock 600cc R6. Yes they are two different bikes, but while the GSX-R had gobs of torque - the R6 was a well-balanced bike that just plain allowed you to go faster (with MUCH less torque).
Bottom line, they are two VERY different cars that offer AWESOME, but unique, driving experiences. If I could own both, I would, but as of this writing, the vette is the best compromise between handling, torque, horsepower, braking (well...sorta), comfort, and fuel-economy (oddly enough) of all the [sports] cars I've owned.
...and, once I fix the broken valve spring, find the source of my P0410 code, find the source of my active-handling/abs issue, and prevent my clutch from sticking to the floor, I'll probably be pretty darn happy with this piece of...American pie.
#38
FYI your on a corvette forum. Most people with v8's are not going to enjoy a small 4cyl at 8-9k rpms. Just one of those opinion things that people are not gonna agree on.
#39
I guess this could be a project if I decided to get one and the low end torque was an issue.
#40
